hello
can any one help in changing gamma of the copied viewport from to 1.0 to 2.2?
http://www.scriptspot.com/3ds-max/scripts/copy-viewport-to-clipboard
macroScript Copy_Viewport_To_Clipboard
buttontext:"Copy Viewport"
Category:"CG_Tools"
tooltip:"Copy Viewport To Clipboard"
if setclipboardbitmap != undefined then --check whether command is undefined... if so then avg not installed or using pre 3ds max 7...
therender = gw.getViewportDib() --new to max 6...
if therender != undefined do
setclipboardbitmap therender --clipboard access via AVG extension (in version 6 at least)
therender = null
gc() --making sure it doesn't sit in memory any longer than needed...
theerrormsg = "This script requires Larry Minton's AVGuard extension. You can download it from scriptspot.com or your favorite max plugin site."
messagebox theerrormsg title: "AVGuard Extension Not Found"
Read this: http://www.klaasnienhuis.nl/2014/07/changing-gamma-pictures-revisited/
Try this script.
b1 = gw.getViewportDib()
b1.filename = @"c:\temp\b1.hdr"
save b1
close b1
free b1
b1 = openBitMap @"c:\Temp\b1.hdr" gamma:0.5
setclipboardbitmap b1
close b1
free b1
