Help me get this script work in Edit Poly Modifier
By pedro · 2015-02-25
Right now I have this script and it works perfectly in Editable Poly. But I decided to update it to work in Edit Poly as well.
It's not working very well :)
This is a smart script that I have assigned to a single key and does diferent things depending on subobject and number of things selected.
macroScript SuperSmartCreate
category:"Pedro Scripts"
toolTip:"Super Smart Create"
	local curObj = modPanel.getCurrentObject()
	Case (classOf curObj) of
		Edit_Poly:
		(Case subobjectlevel of
			 1: ($.modifiers[#Edit_Poly].ButtonOp #ConnectVertices)
			 2:	(if (((curObj.getSelection #edge) as array).count == 0) then
					messagebox "Put the create face code here."
				 local doBridgeConnect = false
				 Edgs = curObj.GetSelection #edge as array
				 case (Edgs.count) of
					1: (
						--Inserts a vertex in the selected edge
						curObj.divideEdge (Edgs[1]) 0.5
						curObj.commit()
						subobjectLevel = 1
					2: (
							EdgA = PolyOp.getEdgeVerts  curObj Edgs[1]
							EdgB = PolyOp.getEdgeVerts  curObj Edgs[2]
							if (EdgA[2]==EdgB[1]) then
								curObj.CreateFace #(EdgA[1],EdgA[2],EdgB[2])
							) else
							if (EdgB[2] == EdgA[1]) then
								curObj.CreateFace #(EdgB[1],EdgB[2],EdgA[2])
							) else
								  doBridgeConnect = true
					default: ( doBridgeConnect = true )
				 if doBridgeConnect then
					 curObj.bridgeSelected = 1
					 if not (curObj.EditablePoly.Bridge()) then
						 --curObj.connectEdgeSegments = 1
						 $.modifiers[#Edit_Poly].ButtonOp #ConnectEdges
			 3:	($.modifiers[#Edit_Poly].ButtonOp #Cap)
			 4:	(if (((curObj.getSelection #face) as array).count < 2) then
						$.modifiers[#Edit_Poly].ButtonOp #BridgePolygon
			 5:()
		Editable_poly:
			 1: (curObj.EditablePoly.ConnectVertices ())
			 2:	(if (((polyop.getEdgeSelection $.baseobject) as array).count == 0) then
					macros.run "Editable Polygon Object" "EPoly_ECreate"
				 Edgs = polyop.GetEdgeSelection $ as array
					1: (
						curObj.EditablePoly.divideEdge (Edgs[1]) 0.5 select:on
						subobjectLevel = 1
					2: (
							) else
							) else
						 curObj.EditablePoly.ConnectEdges ()
			 3:	(curObj.EditablePoly.capHoles #Edge)
			 4:	(if ((($.GetSelection #Face) as array).count < 2) then
					 macros.run "Editable Polygon Object" "EPoly_Create"
						$.bridgeSelected = 1
						$.EditablePoly.Bridge ()
			 5:()
		unwrap_uvw:
		(Case SubobjectLevel of
			1: ()
			2: ()
			3: ()
pixamoon
different methods for Edit_Poly
There are different functions, methods for Edit_Poly Modifier.
You can find everything in max script help.
For example to get vertices:
Editable_Poly:
Edit_Poly:
EdgA[1] = #()
EdgA[1] = curObj.GetEdgeVertex Edgs[1] 1
EdgA[2] = curObj.GetEdgeVertex Edgs[1] 2
end so on...
I changed some stuff in code, so connect edges works now, but you need to finish other parts. Please see attached.
Hope this helps :)
Pixamoon
