Help - keep last used values
By jsrocha · 2011-12-16
Hi guys, how´s going?
i wrote a little script to make extruded faces with chamfered edges, and i was wondering how i could make the last values saved. Because everytime i open the script i need to fill the fields (specially the spinner). Can anyone help me with that? i´m posting an image of the script rollout. I can post the code also if anyone feels that is useful.
Thanks in advance,
Jsrocha
Comments (10)
Here the script, modified by me. :)
Reply to miauu
jsrocha
Hi miauu, thanks a lot, it works perfectly!! I also noticed that you made a lot of improvments and adjustments to my code, i´ll take a look later to try to learn something of it.
Tanks again,
Jsrocha
HI, jsrocha!  Later this day
HI, jsrocha!
 Later this day I will have more time and will look at your code. Meanwhile take a look at THIS THREAD.
Use the INI file to store tha last value when user close the script. Then, when the script is started its will read the last value from the ini file. YOu can store the state of the radiobuttons if you wish.
Reply to miauu
jsrocha
Hey Miauu, thanks for your help. I don´t know how to store the last values in this "ini" file, but i´ll try to find out how to do it.
i´m posting the code in another post, just in case you want to take a look.
thanks again,
Jsrocha
Alen
Can you please post the code?
Reply to Alen
jsrocha
Hi Alen, here is the code:
macroScript chamfer_frame
category:"Juliano"
toolTip:""
rollout chamfrollout "Chamfer frame" width:162 height:250
button botao2 "Chamfro" pos:[69,78] width:84 height:46
spinner xx "espessura" pos:[21,16] width:120 height:16 range:[0,100,3] type:#float
radioButtons sc "chamfro_mm" pos:[23,48] width:29 height:94 labels:#("1", "2", "3", "4", "5")
radioButtons sh "shell mode" pos:[23,150] width:29 height:94 labels:#("both","in","out")
radioButtons chf_side "chamfer side" pos:[23,190] width:29 height:94 labels:#("both","front")
on botao2 pressed do
esp = xx.value
(if sc.state == 1 then chamf = 1.0)
(if sc.state == 2 then chamf = 2.0)
(if sc.state == 3 then chamf = 3.0)
(if sc.state == 4 then chamf = 4.0)
(if sc.state == 5 then chamf = 5.0)
(if -- início da condição de inches units
units.SystemType == #inches
then
chamf = chamf / 2.54
(if
then
esp = esp / 2.54
) -- fim da condição de inches units
(if
sh.state == 1
then
modPanel.addModToSelection (Shell ()) ui:on
$.modifiers[#Shell].innerAmount = esp / 2.0 - chamf / 10.0
$.modifiers[#Shell].outerAmount = esp / 2.0 - chamf / 10.0
$.modifiers[#Shell].selectInnerFaces = on
(if
sh.state == 2
then
$.modifiers[#Shell].innerAmount = esp - chamf / 5.0
$.modifiers[#Shell].outerAmount = 0
(if
sh.state == 3
then
$.modifiers[#Shell].innerAmount = 0
$.modifiers[#Shell].outerAmount = esp - chamf / 5.0
(if
chf_side.state ==1 -- condição p/ chamfrar em ambos os lados
then
(if
chf_side.state ==2 -- condição p/ chamfrar somente na face frontal
then
$.modifiers[#Shell].selectInnerFaces = off
subobjectLevel = 0
$.modifiers[#Shell].selectOuterFaces = on
subobjectLevel = 0
$.modifiers[#Shell].straightenCorners = on
macros.run "Modifiers" "EditPolyMod"
subobjectLevel = 4
$.modifiers[#Edit_Poly].SetOperation #Bevel
$.modifiers[#Edit_Poly].bevelType = 1
$.modifiers[#Edit_Poly].bevelHeight = 0.05 * chamf
$.modifiers[#Edit_Poly].bevelOutline = -0.014 * chamf
$.modifiers[#Edit_Poly].CommitAndRepeat ()
$.modifiers[#Edit_Poly].bevelHeight = 0.036 * chamf
$.modifiers[#Edit_Poly].bevelOutline = -0.036 * chamf
$.modifiers[#Edit_Poly].bevelHeight = 0.014 * chamf
$.modifiers[#Edit_Poly].bevelOutline = -0.05 * chamf
$.modifiers[#Edit_Poly].Commit ()
subobjectLevel = 0
modPanel.setCurrentObject $.modifiers[#Edit_Poly]
$.modifiers[#Shell].selectOuterFaces = off
deleteModifier $ 1
createdialog chamfrollout
i´m a poor coder, everything i do is based in studing another people codes, some maxscript help and listener, so please excuse the coding mistakes (must be some of them).
Best regards,
Jsrocha
Reply to jsrocha
Alen
I made some quick adjustments which might help you. It keeps the values saved as long as max is active.
I added this to the beginning (before rollout):
if spnValue == undefined then
spnValue=3
changed this line:
spinner xx "espessura" pos:[21,16] width:120 height:16 range:[0,100,spnValue] type:#float
and added:
esp = xx.value
spnValue=xx.value
You can do the same thing for the rest of the controls. If this works for you I can make the necessary edits and send the script back to you.
Reply to Alen
jsrocha
Hi Alen, thanks a lot. I´ll study your code to try to use it in this and another codes.
Cheers,
Jsrocha
