Maxscript Rollout Handler Exception --unable to convert: undefined to string
Hi I've been working on my RockMaker script adding a number of changes and have become stuck.
I got some help from Miauu http://area.autodesk.com/forum/autodesk-3ds-max/maxscript/save-ini-setti… via a snippet he posted as a reply to my begging for help.
1. I have had some success integrating most of it into my script but need the presets to load on script run.
2. I also need to feed the presets back into the scripts spinners.
3. If there's no ini file in place the script fails so I need to set some conditions here as well.
4. I have a lot of spinners that have a lot of checking to see if the Rock has been deleted or not. Is it possible to enclose all of these in one check instead of 19 little ones, or do I make them un enabled instead? I'm enjoying the challenges this has posed so far but my medication must be too strong as my mind is drawing a blank lol So any and all help appreciated
Script: RockMaker2.5.ms
Author: Luke Pettit
e-mail: petluke@gmail.com
Date: 01/09/2010-06/04/2011 v 2.1
Date: 17/07/2011 v 2.5
Based on a tutorial by Sascha Henrichs http://saschahenrichs.blogspot.com/
if ((rockRollout != undefined) and (rockRollout.isDisplayed)) do (destroyDialog rockRollout)
iniFile = getFilenamePath (getSourceFileName()) + "/rockMaker.ini"
global allSavedPresets = (readValue ((getINISetting iniFile "Presets" "names") as stringStream))
rollout rockRollout "Rock Maker v2.5"
-- change the arrays values to save the new preset with new values
local rockSet = #(200,5,3,6,30,200,200,true,false,3,110,3,110,1.5,0.8,30,100,270,6,30,100,10,10)
local mRoc, mTurb, mTS, mDM1, mDM2, mNGD, mNFD
spinner spn_Size "Rock Size: " pos:[58,24] width:110 height:16 range:[1,1000,100] type:#float
spinner spn_Segs "Segments: " pos:[58,46] width:110 height:16 range:[1,10,5] type:#integer
spinner spnItt1 "TS Iteration: " pos:[58,68] width:110 height:16 range:[0,10,3] type:#integer
spinner spnRit "TSR Iteration: " pos:[58,89] width:110 height:16 range:[0,100,6] type:#integer
GroupBox grSize "Rock size" pos:[8,8] width:168 height:107
GroupBox grDis "Displace Basic Shape" pos:[184,8] width:168 height:206
spinner spnStr1 "Strength: " pos:[235,24] width:110 height:16 range:[-1000,10000,130] type:#float
spinner spxOff "X Offset: " pos:[235,47] width:110 height:16 range:[1,10000,100] type:#integer
spinner spzOff "Z Offset: " pos:[235,69] width:110 height:16 range:[1,10000,100] type:#integer
radiobuttons radBut "" pos:[208,89] width:58 height:32 labels:#("Circular", "Chips") default:1 columns:1 across:1
checkbox chkFrac "Fractal " pos:[279,94] width:57 height:15 checked:false
spinner spnItt4 "Iterations: " pos:[235,124] width:110 height:16 enabled:false range:[1,100,3] type:#integer
spinner spcSize "Cell Size: " pos:[235,146] width:110 height:16 range:[1,10000,110] type:#float
spinner spcSpr "Spread: " pos:[235,168] width:110 height:16 range:[0.1,10,1.5] type:#float
spinner spnMidT "Mid Threshold: " pos:[235,190] width:110 height:16 range:[0.1,1,0.8] type:#float
GroupBox grp1 "Displace Medium Details" pos:[8,120] width:168 height:64
spinner spnStr2 "Strength: " pos:[58,137] width:110 height:16 range:[-1000,1000,30] type:#float
spinner spcSize2 "Cell Size: " pos:[58,160] width:110 height:16 range:[1,1000,100] type:#float
GroupBox grp2 "Noise Grain Detail" pos:[8,190] width:168 height:90
spinner spnSca "Scale: " pos:[58,208] width:110 height:16 range:[1,1000,270] type:#float
spinner spnItt2 "Iterations: " pos:[58,232] width:110 height:16 range:[1,100,6] type:#integer
spinner spnStr3 "StrenghtXYZ: " pos:[58,256] width:110 height:16 range:[1,100,30] type:#float
GroupBox grp3 "Noise Fine Detail" pos:[8,288] width:168 height:89
spinner spnSca2 "Scale: " pos:[58,305] width:110 height:16 range:[1,1000,100] type:#float
spinner spnItt3 "Iterations: " pos:[58,328] width:110 height:16 range:[1,100,10] type:#float
spinner spnStr4 "StrenghtXYZ: " pos:[58,352] width:110 height:16 range:[1,100,10] type:#float
button dRock "Delete Rock" pos:[185,219] width:70 height:20 toolTip:"Press this button to delete the Rock"
button btn_pivot "Pivot C/B" pos:[260,219] width:75 height:20 toolTip:"Press this button to place the pivot to the base or centre"
button btn_pHelp "?" width:13 pos:[340,219] height:20 toolTip:"Pivot help"
button btnRockMe "Rock Me!" pos:[185,243] width:167 height:25 toolTip:"Press this button to create a Rock" --Button creation
button lpRock "Make Low Poly" pos:[185,272] width:80 height:20 toolTip:"Make low poly rock from selection"
button btn_Bake "RTT" pos:[272,272] width:80 height:20 toolTip:"Open the Render to Texture Dialog"
button cAbout "About" pos:[185,297] width:80 height:18 toolTip:"About"
button cExit "Exit" pos:[272,297] width:80 height:18 toolTip:"Press this button to close the Rock Maker"
label lbl_no1 "=====================" pos:[185,317]
dropdownList LoadPresets "" items:allSavedPresets pos:[185,333] width:167 height:10
button btn_DelPreset "Delete Presets"pos:[185,359] width:78 height:18 toolTip:"Delete presets"
button btn_SavePresets "Save Presets" pos:[272,359] width:78 height:18 toolTip:"Save presets"
on btnRockMe pressed do
for obj in selection do
delete obj
mRoc = box length:spn_Size.value width:spn_Size.value height:spn_Size.value pos:[0.0, 0.0, 0.0] \
lengthsegs:spn_Segs.value widthsegs:spn_Segs.value heightsegs:spn_Segs.value isSelected:true
mRoc.mapcoords = true
mRoc.name = uniqueName "Rock"
mRS = (spherify())
addModifier mRoc mRS
mTS = (turbosmooth iterations:spnItt1.value useRenderIterations:true renderiterations:spnRit.value)
addModifier mRoc mTS
mDM1 = (displace name:"Displace Basic Shape" strength:spnStr1.value maptype:2.0)
addModifier mRoc mDM1
mDM2 = (displace name:"Displace Medium Details" strength:spnStr2.value maptype:2.0 )
addModifier mRoc mDM2
mNGD = (Noisemodifier name:"Noise Grain Detail" scale:spnSca.value fractal:on iterations:spnItt2.value)
addModifier mRoc mNGD
mNFD = (Noisemodifier name:"Noise Fine Detail" scale:spnSca2.value fractal:on iterations:spnItt3.value)
addModifier mRoc mNFD
addModifier mRoc (FFDBox ())
setDimensions mRoc.modifiers[#FFD_box__4x4x4] [2,2,3]
mRoc.Displace_Basic_Shape.map = Cellular()
mRoc.Displace_Basic_Shape.map.coords.offset = [spxOff.value, 0.0, spxOff.value]
mRoc.Displace_Basic_Shape.map.cellcolor = (color 0 0 0)
mRoc.Displace_Basic_Shape.map.variation = 5.8
mRoc.Displace_Basic_Shape.map.divcolor1 = (color 158 158 158)
mRoc.Displace_Basic_Shape.map.divcolor2 = (color 112 112 112)
mRoc.Displace_Basic_Shape.map.type = 0
mRoc.Displace_Basic_Shape.map.fractal = off
mRoc.Displace_Basic_Shape.map.iteration = spnItt4.value
mRoc.Displace_Basic_Shape.map.size = spcSize.value
mRoc.Displace_Basic_Shape.map.spread = spcSpr.value
mRoc.Displace_Basic_Shape.map.midthresh = spnMidT.value
mRoc.Displace_Medium_Details.map = noise()
mRoc.Displace_Medium_Details.map.type = 1
mRoc.Displace_Medium_Details.map.size = spcSize2.value
mRoc.Displace_Medium_Details.map.thresholdHigh = 0.9
mRoc.Displace_Medium_Details.map.thresholdLow = 0.2
mRoc.Displace_Medium_Details.map.levels = 10.0
mRoc.Noise_Grain_Detail.strength = [spnStr3.value, spnStr3.value, spnStr3.value]
mRoc.Noise_Fine_Detail.strength = [spnStr4.value, spnStr4.value, spnStr4.value]
on spn_Size changed val do
if mRoc != undefined and not isdeleted mRoc do
mRoc.length = mRoc.width = mRoc.height = val
on spnStr1 changed val do
mDM1.strength = val
on spn_Segs changed val do
mRoc.lengthsegs = mRoc.widthsegs = mRoc.heightsegs = val
on spnItt1 changed val do
mTS.iterations = val
on spnRit changed val do
mTS.renderiterations = val
on spxOff changed val do
mRoc.Displace_Basic_Shape.map.coords.offset = [val, 0.0, spzOff.value]
on spzOff changed val do
mRoc.Displace_Basic_Shape.map.coords.offset = [spxOff.value, 0.0, val]
on radBut changed state do
mRoc.Displace_Basic_Shape.map.type = state - 1
on chkFrac changed state do
mRoc.Displace_Basic_Shape.map.fractal = state
if state == on then
spnItt4.enabled = true
spnItt4.enabled = false
on spnItt4 changed val do
mRoc.Displace_Basic_Shape.map.iteration = val
on spcSize changed val do
mRoc.Displace_Basic_Shape.map.size = val
on spcSpr changed val do
mRoc.Displace_Basic_Shape.map.spread = val
on spnMidT changed val do
mRoc.Displace_Basic_Shape.map.midthresh = val
on spnStr2 changed val do
mDM2.strength = val
on spcSize2 changed val do
mRoc.Displace_Medium_Details.map.size = val
on spnSca changed val do
mNGD.scale = val
on spnItt2 changed val do
mNGD.iterations = val
on spnStr3 changed val do
mRoc.Noise_Grain_Detail.strength = [val, val, val]
on spnSca2 changed val do
mNFD.scale = val
on spnItt3 changed val do
mNFD.iterations = val
on spnStr4 changed val do
mRoc.Noise_Fine_Detail.strength = [val, val, val]
on dRock pressed do -- when btn is pressed do...
if (selection.count>0) then
delete obj
messagebox "You must have at least one Rock selected!" title:"Computer says no..." beep:false
on cExit pressed do
on btn_pivot pressed do
if mRoc != undefined and not isdeleted mRoc then
ResetPivot mRoc
CenterPivot mRoc
for i in selection do
i.pivot = [i.pivot.x, i.pivot.y, i.min.z]
mRoc.pos = [0,0,0]
)else (messagebox "You must have at least one Rock selected!" title:"Computer says no..." beep:false)
on btn_pHelp pressed do
messageBox "The Pivot C/B button works in two ways\n\n1. If the rock is not selected then it will centre the pivot to the rock\n and centre the rock to pos:[0,0,0]\n2. If the rock is selected it will place the pivot to the bottom\n of the rock and centre the rock to pos:[0,0,0]" title:"petluke@gmail.com" beep:false
on btn_SavePresets pressed do
rollout editTextSaveP "Save Presets"
local presetName = undefined
editText edittxt_prst_name "" bold:true
button btn_SavePrst "Save"
on editTextSaveP open do
on edittxt_prst_name entered txt do
if txt != "" then
presetName = txt as string
on btn_SavePrst pressed do
if allSavedPresets.count !=0 then
store = allSavedPresets
store = #() as array
if rockSet != 0 then
append store presetName
setIniSetting iniFile "Presets" "names" (store as string)
setIniSetting iniFile presetName "spn_Size" (spn_Size.value as string)
setIniSetting iniFile presetName "spn_Segs" (spn_Segs.value as string)
setIniSetting iniFile presetName "spnItt1" (spnItt1.value as string)
setIniSetting iniFile presetName "spnRit" (spnRit.value as string)
setIniSetting iniFile presetName "spnStr1" (spnStr1.value as string)
setIniSetting iniFile presetName "spxOff" (spxOff.value as string)
setIniSetting iniFile presetName "spzOff" (spzOff.value as string)
setIniSetting iniFile presetName "radBut" (radBut.state as string)
setIniSetting iniFile presetName "chkFrac" (chkFrac.state as string)
setIniSetting iniFile presetName "spnItt4" (spnItt4.value as string)
setIniSetting iniFile presetName "spcSize" (spcSize.value as string)
setIniSetting iniFile presetName "spcSpr" (spcSpr.value as string)
setIniSetting iniFile presetName "spnMidT" (spnMidT.value as string)
setIniSetting iniFile presetName "spnStr2" (spnStr2.value as string)
setIniSetting iniFile presetName "spcSize2" (spcSize2.value as string)
setIniSetting iniFile presetName "spnSca" (spnSca.value as string)
setIniSetting iniFile presetName "spnItt2" (spnItt2.value as string)
setIniSetting iniFile presetName "spnStr3" (spnStr3.value as string)
setIniSetting iniFile presetName "spnSca2" (spnSca2.value as string)
setIniSetting iniFile presetName "spnItt3" (spnItt3.value as string)
setIniSetting iniFile presetName "spnStr4" (spnStr4.value as string)
LoadPresets.items = allSavedPresets
)else
messagebox "You can not creat empty preset!"
destroydialog editTextSaveP
createdialog editTextSaveP
on btn_DelPreset pressed do
prstToDelName = LoadPresets.selected
prstToDelNumb = LoadPresets.selection
if prstToDelNumb > 1 then
delIniSetting iniFile prstToDelName
deleteItem allSavedPresets prstToDelNumb
setIniSetting iniFile "Presets" "names" (allSavedPresets as string)
LoadPresets.selection = prstToDelNumb-1
newPrstToShow = prstToDelNumb-1
if prstToDelNumb != 2 then
print newPrstToShow
on LoadPresets selected itm do
if itm != 1 then
print itm
on lpRock pressed do --make low poly Rock, clone Rock and unwrap and add projection modifier
try(
max modify mode
theBox = mRoc
theCopy = copy theBox --create a copy of the first box, store in a variable
theCopy.name = uniquename (theBox.name + "Copy") --rename the copy
theCopy.modifiers[#TurboSmooth].iterations = 0
convertToPoly theCopy
select theCopy
theUnw = Unwrap_UVW ()
addModifier theCopy theUnw
modPanel.setCurrentObject theCopy.modifiers[#Unwrap_UVW]
SubObjectlevel = 1
theCopy.modifiers[#unwrap_uvw].unwrap2.setIgnoreBackFaceCull off
theCopy.modifiers[#unwrap_uvw].unwrap6.selectVerticesByNode #{1..730} $
theCopy.modifiers[#unwrap_uvw].unwrap2.fitRelax 50 0.1
theCopy.modifiers[#unwrap_uvw].unwrap2.packNoParams()
theCopy.modifiers[#unwrap_UVW].unwrap2.scaleSelectedCenter 0.98 0
theProj = ProjectionMod() --create a projection modifier
addModifier theCopy theProj
theProj.addObjectNode theBox
theProj.autowrapCage()
theProj.addRegisteredProjectionType 1
theProj.projectProjectionType 1
)catch()
on btn_Bake pressed do try(macros.run "Render" "BakeDialog")catch()
on cAbout pressed do
messageBox "Script by Luke Pettit\nhttp://lukepettit-3d.blogspot.com\n\nBased on the Sascha Henrichs Tutorial\nhttp://saschahenrichs.blogspot.com/" title:"petluke@gmail.com" beep:false
createdialog rockRollout 360 385 pos:[800, 135]
Wooo Hoooo fantastic miauu thanks a lot. It turns out one of the many problems was my ini file that I was using, it also had something wrong with it, which was causing me errors I couldn't understand.
Here the solution for 1,2 and 3 :) The script will generate the ini file if it not exist. :)
