Help generate maxscript sequent report
By fajar · 2011-11-03
MyLog = "c:\\MyBitmapCollector.log"
ini_file = createFile MyLog
ToMyLog = openFile MyLog mode:"at"
Sep = "//============================================\\\\"
format "%\n" sep to:ToMyLog
txt = ""
format "%\n" txt to:ToMyLog
txt = "Total Scene Bitmap : " + (g as string) +" Files"
txt = "Total Collected Bitmap : " + (u as string) +" Files"
txt = "Total Missing Bitmap : " + (h as string) + " Files"
txt = "________________________________________"
if ((u=g) ==true )then txtLog= "All file copied without fail" else txtLog= "Theres still missing bitmap that still not copied"
format "%\n" txtLog to:ToMyLog
txt = ""
Sep = "\\\\============================================//"
close ini_file
Hi everybody, I need help to create sequential report for my script, basicly I already made script, like those above, but it didnt generate sequent report, like I wanted. From script above if you execute it, it should create file c:\\MyBitmapCollector.log and contain report like this in it :
(THIS IS DATA REPORT THAT ALREADY EXIST)
Total Scene Bitmap : 3 Files
Total Collected Bitmap : 1 Files
Total Missing Bitmap : 2 Files
but after execute it again, instead of append new report in my log, it just flush all data in my log. How do I append into below the data report that currently exist in my log ?
Big Thanks
fajar
fajar
as expected from anubis...
thanks anubis
Hey Fajar,
As you need to append then create your file just once. Here is...
-- create the file once
if not doesFileExist MyLog do (
	close ini_file -- !
-- example sequence
for file in arrFiles do
	loadMaxFile file quiet:on
	--// <write2file_code_here>
	close ToMyLog -- !
Ofer Zelichover
just delete the line: ini_file = createFile MyLog
createFile always creates a new (empty) file.
Cheers,
o
