hi... im new to scripting... how to dynamically update the "label" while selecting edges in Editable poly--- the idea is i want to update the label to the "number of edges selected"... ive started a script already but i dont know how to write the code to dynamically update it... i think its a callback thing... thanks in advance....
this is the script..
rollout test "test"
label label1 "test label"
fn labelcallback =
label1.text = ($.selectedEdges.count as string) + " edges selected"
on test open do labelcallback()
createDialog test
Hi ...you can use this
Hi ....
you can use this function:
such as :
hi budi G... thanks for the reply... i tested it and it works:).. thank you so much for the code now i can i finish my script...
thanks again
