Hello. how make a color complementary in two color pickers at same time, please
By Juan Botero · 2013-04-11
Hello to every body. i have this script
Rollout twocolor "complementary "
Group "complimentary color:"
colorpicker theColor_ct  color:[0,0,255] modal:false  across:2
colorpicker theColorb  color:[255,156,0] modal:false
   on theColor_ct changed new_colct do theColorb.color = new_colct
   on theColorb changed new_colb do theColor_ct.color = new_colb
createDialog twocolor 280 50
I could connect the two color picker, but as you can see gives the same color, please how should be the code so when i select a color in "theColor_ct", the color in the "theColorb" it will be the complementary and  backwards?
Thnaks for you time.😉
themaxxer
works like a charm... thanks.
could you make it as macro script? I can't do it.
thanks
themaxxer
Reply to themaxxer
macroScript complementary category:"le1setreter" toolTip:"complementary in two color"
try(destroyDialog ::twocolor)catch()
fn getComplColor baseColor =
origR = baseColor.r
origG = baseColor.g
origB = baseColor.b
minRGB = amin origR origG origB
maxRGB = amax origR origG origB
minPlusMax = minRGB + maxRGB
complColor = color (minPlusMax-origR) (minPlusMax-origG) (minPlusMax-origB)
on theColor_ct changed new_colct do theColorb.color = getComplColor new_colct
on theColorb changed new_colb do theColor_ct.color = getComplColor new_colb
createDialog twocolor 280 50 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
le1setreter
try with this function:
		origR = baseColor.r
		origG = baseColor.g
		origB = baseColor.b
i am not sure if the values are 100% exact. i took the formula from here:
http://forum.processing.org/topic/the-opposite-of-a-color
