Greying out Buttons
By blug · 2012-12-05
HI guys,
Most like a simple one for most of you but this is giving me a little bit of a headache.
I am trying to grey out (make unclickable) all my buttons in my rollout unless a condition (a box exists in the scene) is met but I cant get it to work. The "bounding box" button creates the box I want in the scene.
Should this be done through .enabled? Should I make the conditional check on the box a loop?
rollout threepointlight "3 Point Lighting"
	group "Bounding Box"
    button But_info "Usage Guide" enabled:true
	button But_BoundingBox "Build Bounding Box" enabled:true
	button but_BoundingBoxToggle "Hide Bounding Box"
    button but_BoundingBoxToggle2 "Show Bounding Box"
	on But_BoundingBox pressed do
		box height:150 width:150 length:150 pos:[0,0,0]
	on But_info pressed do messagebox "Place and Scale your object inside the Bounding box for this script to work"
	on but_BoundingBoxToggle pressed do hide $Box001
	on but_BoundingBoxToggle2 pressed do unhide $Box001
	-- Lighting section
	group "Lights"
	button but_buildlights1 "Build Omni one" enabled:false
	on but_buildlights1 pressed do
		l1=MiAreaLightomni pos:[0,0,370]  $.castShadows = on  $.useGlobalShadowSettings = on $.multiplier = 0.70 $.rgb = color 178 178 178
	button but_buildlights2 "Build Omni Two" enabled:false
	on but_buildlights2 pressed do
		l2=MiAreaLightomni pos:[0,370,-150] intensity:1.0 shadows:false
	button but_buildlights3 "Build Omni Three" enabled:false
	on but_buildlights3 pressed do
		l3=MiAreaLightomni pos:[370,45,150] intensity:1.0 shadows:true
	colorpicker L1_d "Light one Color"
	 color:[255,255,255] align:#right offset:[-20,0] fieldwidth: 20 enabled:false
	colorpicker L2_d "Light two Color"
	 color:[0,0,255] align:#right offset:[-20,0] fieldwidth: 20 enabled:false
	colorpicker l3_d "Light three Color"
	 color:[255,0,0] align:#right  offset:[-20,0] fieldwidth: 20 enabled:false
	button But_AddSky "Add SkyLight" enabled:true
    spinner spn_skyIntense "Skylight Intensity" enabled:false
	range:[0.0,1.0,1.0]
		on But_AddSky pressed do
		skylight pos:[0,0,0]
createDialog threepointlight height:700 width:300
Sorry if this has been covered a lot, Ive just stepped into the world of maxscripting.
blug
Thanks for the responses guys! They are very helpful.
fajar
maybe you want it something like this==
Theres a box , all grayed btn is ungrayed
 theres no box , all back to grayed button
fn doGraytheAllBut btn1 btn2 btn3 btn4 btn5 btn6=
	theBoxExistOrNot=for i in geometry where classOf i == box collect i
	if theBoxExistOrNot.count!=0 then
		btn1.enabled=true
		btn2.enabled=true
		btn3.enabled=true
		btn4.enabled=true
		btn5.enabled=true
		btn6.enabled=true
		btn1.enabled=false
		btn2.enabled=false
		btn3.enabled=false
		btn4.enabled=false
		btn5.enabled=false
		btn6.enabled=false
rollout threepointlight "3 Point Lighting" width:162 height:234
	GroupBox grp01 "Bounding Box" pos:[2,1] width:156 height:82
	GroupBox grp02 "Lights" pos:[2,85] width:155 height:108
	button But_info "Usage Guide" pos:[7,167] width:145 height:21 enabled:true
	button But_BoundingBox "Build Bounding Box" pos:[5,16] width:149 height:19 enabled:true
	button but_BoundingBoxToggle "Hide Bounding Box" pos:[5,36] width:149 height:21 enabled:false
	button but_BoundingBoxToggle2 "Show Bounding Box" pos:[6,57] width:148 height:21 enabled:false
	button but_buildlights1 "Build Omni one" pos:[7,101] width:122 height:21 enabled:false
	button but_buildlights2 "Build Omni Two" pos:[7,123] width:122 height:21 enabled:false
	button but_buildlights3 "Build Omni Three" pos:[7,145] width:122 height:21 enabled:false
	-- Lighting secti
	on threepointlight open do
		callbacks.addScript #nodePostDelete "doGraytheAllBut threepointlight.But_info threepointlight.but_BoundingBoxToggle threepointlight.but_BoundingBoxToggle2 threepointlight.but_buildlights1 threepointlight.but_buildlights2 threepointlight.but_buildlights3" id:#CheckBBox
		callbacks.addScript #sceneNodeAdded "doGraytheAllBut threepointlight.But_info threepointlight.but_BoundingBoxToggle threepointlight.but_BoundingBoxToggle2 threepointlight.but_buildlights1 threepointlight.but_buildlights2 threepointlight.but_buildlights3" id:#CheckBBox
		--callbacks.addScript #selectionSetChanged "doGraytheAllBut threepointlight.But_info threepointlight.but_BoundingBoxToggle threepointlight.but_BoundingBoxToggle2 threepointlight.but_buildlights1 threepointlight.but_buildlights2 threepointlight.but_buildlights3" id:#CheckBBox
	on threepointlight close do
		callbacks.removeScripts #nodePostDelete id:#CheckBBox
		callbacks.removeScripts #nodeCreated id:#CheckBBox
	colorPicker L1_d "" pos:[129,102] width:22 height:20 enabled:false color:[255,255,255] fieldWidth:20
	colorPicker L2_d "" pos:[129,124] width:22 height:20 enabled:false color:[0,0,255] fieldWidth:20
	colorPicker l3_d "" pos:[129,146] width:22 height:20 enabled:false color:[255,0,0] fieldWidth:20
	button But_AddSky "Add SkyLight" pos:[7,210] width:73 height:21 enabled:true
	spinner spn_skyIntense "Val:" pos:[94,213] width:59 height:16 enabled:false range:[0,1,1]
	GroupBox grp5 "Lights" pos:[3,193] width:155 height:40
		(box height:150 width:150 length:150 pos:[0,0,0])
		hide $Box001
		unhide $Box001
createDialog threepointlight width:162 height:234
Thats only raw basic script based on in scene objects if theres box object or not...you can change it tho for your personal purpose with another.You can add a name in box and later use it as identification of your unique object.
welcome to scripting then ;)
What I'll say is almost the same. You already answer ourself. The "enabled" property control that state:
myControlName.enabled = on/off (true/false)
Also, if I remember,
rollout.controls
was mapped array, that mean you can set some property on multiple controls at once (w/o for-loop):
myRolloutName.controls.enabled = true/false
Here is some sketch:
rollout roP3Ligth "3 Point Lighting"
	local objBBName = "SomeUniqueName101"
	local objBB = undefined
	button btnAddBBox "Make BBox" enabled:false
	checkButton cbtnBBoxVisTogle "Hide BBox"
	button btnAddLight1 "Add Omni one"
	-- ... and so on...
	on btnAddBBox pressed do
		objBB = box name:objBBName \
	on cbtnBBoxVisTogle changed state do
	(objBB.isHidden = state)
	on roP3Ligth open do
		objBB = getNodeByName objBBName
		if not IsValidNode objBB do
			roP3Ligth.controls.enabled = off
			btnAddBBox.enabled = on
You have to use .enabled to make your controls unclickable.
Also, it is better to give the unique name of the bounding box object, something like "Tim270BoundingBoxHelperObject", so you can easily get/check if this box exist in the scene or not.
When you want the script to make your controls unclickable?
If you need this when you run the script then you need to add this in your code:
		for o in geometry where (classof o == Box) and (o.name == "Box001") do
			--	this will make all controls in the rollout unclickable.
			for ctrl in threepointlight.controls do ctrl.enabled = false
