go to frame
By titane357 · 2012-09-13
hello,
I'd like to clic a key -> open window, tape a value and clic enter (numeric)
and voilà : I have set new timeframe.
but I don't know how to validate the value with enter key, I don't want to clic on the "go" button.... please, any idea ?
try destroyDialog rlMover catch()
global rlMover = rollout rlMover "GO2frame"
button butconnect "GO" pos:[2,2]
spinner spX "X " width:90 range:[0,5000,1] type:#integer pos:[55,5]
on spX KeyDOwn evnt do
if evnt.KeyCode == (dotNetClass "System.Windows.Forms.Keys").Enter do
sliderTime = spX.value
createDialog rlMover 160 25
setFocus rlMover.spX
you need to use (dotNetControl "NumericUpDown") if you use keydown event.Thats way not works.
use "Return" instead of "Enter"
if (evnt.KeyCode as string) == "Return" do ...
or you can use keyValue like this
if evnt.keyValue == 13 do ...
try this script to see KeyCode or keyValues of keyboard keys
http://www.scriptspot.com/3ds-max/scripts/key-value
Reply to Branko Živković
titane357
thanks for answer, but unfortunally it don't work for me...
instead I use change value, that's do the trick...
global rlMover = rollout rlMover " GO2frame"
spinner spX ">>> FRAME " width:150 range:[0,5000,1] type:#integer pos:[5,5]
on spX changed val do
Reply to titane357
hey Titane!
Why you use "changed" event of the spinner
then you have "entered"?
on spX entered do ( ... )
