Hi all, I have a problem with a script
This script does work :
if true then (
mybox = box()
myuvw = uvwmap maptype:4
addmodifier mybox myuvw
mymodifier = mybox.modifiers[1]
print mymodifier.gizmo.position
but this one doesn't work:
if true then (
mybox = box()
So, why i can't access to gizmo properties in the if-condition... please help me!!!
Best regards
Just oposite first not works because your variable is in other level (between the bruckets). Second works. First can works only in this form (if you declare variable before "if-then-else" or "if-do" statement)
mymodifier = undefined
if true then
mybox = box()
Thanks barigazy for your quick reply but it's not opposite.
If you can try the both code, the first one works (even if 'mymodifier' is not declared before) and the second one doesn't work!!!
It seems i can't access to gizmo properties inside the if-then statement (or for loop or function)... I don't understand...
found
I found!!! but i don't understand.
The problem happens when the uvwmap is applied to the object inside the if-then statement... it seems i can't create/apply the modifier and transform the gizmo, both, inside the same statement. The issue is to apply the modifier in the if-then statement and modify it in a function... If someone knows what happens, i'd like to understand!
