I'm linking a dwg file into max and the I'm trying to get the the vertices of a line on a certain layer. I know that I have only one line on that layer.
Then I try to create a camera using the retrieved points, but I get only [0,0,0] coordinates.
What am I doing wrong?
The code looks like this:
for i = 0 to layerManager.count-1 do
ilayer = layerManager.getLayer i
layerName = ilayer.name
if matchpattern layerName pattern:"CAM-IN*" do
splitName=filterstring layerName "-"
cameraname=splitName[2]
ilayer.nodes &theNodes
for n in theNodes do
a=n
format "\na = %" a
c=edit_poly()
addmodifier a c
mypoint1 = a.modifiers[#Edit_Poly].Getvertex 1
mypoint2 = a.modifiers[#Edit_Poly].Getvertex 2
format "\n%" layerName
format "\n% - %" mypoint1 mypoint2
max create mode
newcam = TargetCamera name:cameraname pos:mypoint2 target:(TargetObject name:(cameraname + ".Target") pos:mypoint1)
Any advice would be appreciated.
Thank you.
