Maybe this is laughable question however I can't handle with this one.
How to get variable "lInst" outside this code so I could use it in different place of code or diffrent script. Now when I check value of "lInst" inside this expression is different then outside. I tried with return as function and still nothing.
This is my code which search for missing plugins:
local t = stringstream ""
apropos "*missing*" to:t
t = t as string
local l = filterstring t "\n "
local lMissingClasses = #()
for t in l do
if matchpattern t pattern:"missing*" then
local cls = execute t
if matchpattern (cls as string) pattern:"missing*" then
global lInst = getclassinstances cls
----->VARIABLE I WANT TO GET VALUE FROM HERE IS: lInst
----->I WANT HAVE VALUE OF VARIABLE lInst HERE(outside expression above)
still nothing, won't work
Execute the code. The value of lInst will be printed in the listener. Then open maxscript listener, type lInst and press the numpad Enter.
I don't have missing plugins, so the value is always an epmty array.
U already declared your variable as global.
Maybe is better to put it above
global llnst = #()
--. . . rest of the code
