Getting Correct UVW info
By rosuto · 2012-07-13
Im currently fighting with 3dmax to give me the correct information regarding UVW maps. If I have 6 UVW unwraps listed in the modifiers window, all on different channels, and my current selection is editable mesh; 3d max will tell me that only 2 uvw channels exist when I use meshop.getNumMaps geometry[1]. Its not till I click the very top modifier, does it actually give me the correct number of UVW channels. So I tried to do the following work around, but I find it quite time consuming as it takes around 2 seconds to process for each object. I have also tried collapseStack, but that took the same amount of time and I would prefer to not collapse the modifiers list. Is there a faster way to get the information I need?
if (geometry[f].modifiers.count) != 0 then (
  i=1
  do (
    if (geometry[f].modifiers[i].enabled and ((classOf geometry[f].modifiers[i]) == Unwrap_UVW or (classOf geometry[f].modifiers[i])== VertexPaint)) then (
      modpanel.setCurrentObject geometry[f].modifiers[i]
      found = true
    i+= 1
  ) while (found == false and i <= geometry[f].modifiers.count)
if (meshop.getMapSupport geometry[f] 0) then (vertColor = 1)
for i=1 to meshop.getNumMaps geometry[f] do (
  if (meshop.getMapSupport geometry[f] i) then (
    textNum += 1
    append mapVerts (meshop.getNumMapVerts geometry[f] i)
rosuto
Same issue
Lets say my modifiers box looks like
Unwrap UVW (channel 4)
Unwrap UVW (channel 3)
Unwrap UVW (channel 2)
Unwrap UVW (channel 1)
Editable Mesh
So if I click on editable mesh and run the code, it will tell me the there is only 1 map channel. If I click on Unwrap UVW with channel 2, it will tell me that there is 2 map channels.
Now if I switch it up so the order is
Editable Mesh
It will spit 1 for editable mesh, 3 for unwrap uvw channels 1, 2, and 3. And finally 4 for channel 4. So what ever is the highest channel from where I clicked and down, is what it will spit out. I would like it to give me 4 no matter where I clicked or what the order is.
Reply to rosuto
solution2
This work with multiple selection, UnwrapUVW and UVWMap modifiers
if selection.count != 0 do
	local cnt = 1
	for obj in selection where isKindOf obj GeometryClass and not isKindOf obj TargetObject do
		local Channels = #{}
		if obj.modifiers.count != 0 do
			for m in 1 to obj.modifiers.count do
				case classof obj.modifiers[m] of (
					(Unwrap_UVW): append Channels (obj.modifiers[m].getMapChannel())
					(Uvwmap): append Channels obj.modifiers[m].mapChannel
		if Channels.numberset != 0 do
			format "object%: % ; mapchannel:%\n" cnt obj.name Channels.count
			cnt+=1
Try the code and let me know if it works
Reply to rosuto
Yep, because you need only mapchannel value from mods and not mesh faceID's. Reordering of modifiers don't affect final result.
Glad you like it.
Cheers!
solution
A test this code on 3 Cylinder:
Cylinder001 have 6 UVWmap mods with different channels, Cylinder002 have 2 UVWmap etc....
gnm = meshop.getNumMaps
for obj in selection do
local objmesh = snapshotasmesh obj
format "object:% mapchannels:%\n" obj.name ((gnm objmesh)-1)
--result
--object:Cylinder001 mapchannels:5
--object:Cylinder003 mapchannels:2
--object:Cylinder002 mapchannels:3
