getController from array
By JokerMartini · 2013-02-22
Say for example I have an array that contains the numbers which represent a subAnim controller.
How could I build a variable which would allow me to directly get to that controller.
delete objects
obj = teapot()
subIndexes = #(3,1,1) -- SubAnim:X_Position
clearlistener()
-- example b = obj[3][1][1]
-- I need to build an array with the subIndexes that would return SubAnim:X Position
-- Keep in mind that the length of the subIndexes could change depending on the situation.
Comments (8)
JokerMartini
Anubis after further messing around your script returns just the controller, I need it to return the object and controller
ex. Yours returns
'subAnim: X_position'
I need
'Node[3][1][1]'
Which would be the controller path and the node.
Reply to JokerMartini
Soory for intrusion. Maybe this will help
fn returnSubAnim obj arr = (
local sa = obj[arr[1]]
if arr.count > 1 do
for i = 2 to arr.count do
sa = sa[arr[i]]
exprForMaxObject sa -- return result
my function do what you ask for :)
You can work with both "subAnum.value = get/set value" or "controller.value = get/set value", but if you prefer the function to return controller instead of subAnim, then just change last line to "sa.track".
	if arr.count > 1 do
			sa = sa[arr[i]]
	sa.track -- return result
b = box()
c = returnSubAnim b #(3,1,1)
isController c --> true
And Node[3][1][1] is still SubAnim. If you need string, then use
exprForMaxObject
as Branko suggest.
JokerMartini
Anubis! Hey bud.
Thanks for the snippet. It seems like that is more of what I'm after. I'm never a bit fan of execute. Thanks guys.
Hi John
or maybe just...
fn returnSubAnim obj arr = (obj[arr[1]][arr[2]][arr[3]])
woops, I miss last note... the sub tree is not fixed to 3, right?
P.S. corrected:
	if arr.count > 1 do
			sa = sa[arr[i]]
	sa -- return result
JokerMartini
Thank you very much
Hi John
Try this
local str = "$"+obj.name
for i in 1 to arr.count do append str ("[" + arr[i] as string + "]")
execute str
tea = teapot()
returnSubAnim tea subIndexes
