Get Used Material ID List from EditablePoly without face check
By Matyrix · 2018-08-30
Hello,
Everybody on other forums use the check every face to read the Used Material IDs from an object, but there is a basic ID list in Editable Poly. I attached an image about it.
The only problem is that there is no chance to read this list from the Editable Poly.
Do somebody knows how can i read this list by script?
Comments (13)
Panteleev Sergey
You can also make an unsafe version of it and it will work at least two times faster.
if classof ::GetUsedMtlIDs != dotNetMethod do (
	local source = "using Autodesk.Max;
	using System;
	using System.Collections;
	using System.Collections.Generic;
	class MeshMaterialIDs
	static private IGlobal global = GlobalInterface.Instance;
	static private IMesh GetMeshFromNode( IINode node )
		IObject obj = node.EvalWorldState( 0, true ).Obj;
		IClass_ID triClass = global.Class_ID.Create( 9, 0 );
		IClass_ID polyClass = global.Class_ID.Create( 1562457754, 0 );
		IClass_ID patchClass = global.Class_ID.Create( 4144, 0 );
		if ( obj.IsSubClassOf( triClass ) )
			return ((ITriObject)obj).Mesh;
		else if ( obj.IsSubClassOf( polyClass ) )
			ITriObject mesh = (ITriObject)((IPolyObject)obj).ConvertToType( 0, triClass );
			return mesh.Mesh;
		else if ( obj.IsSubClassOf( patchClass ) )
			return ((IPatchObject)obj).GetMesh( 0 );
		else if ( obj.CanConvertToType( triClass ) == 1 )
			ITriObject tri = (ITriObject)obj.ConvertToType( 0, triClass );
			return tri.Mesh_;
			return null;
	static public int[] GetUsedMtlIDs( uint handle )
		IINode node = global.COREInterface.GetINodeByHandle( handle );
		IMesh mesh = GetMeshFromNode( node );
		if ( mesh == null ) return null;
		BitArray used_ids = new BitArray( ushort.MaxValue );
		List<int> material_ids = new List<int>( ushort.MaxValue );
		foreach ( IFace face in mesh.Faces )
			if ( used_ids.Get( face.MatID ) == false )
				material_ids.Add( face.MatID + 1 );
				used_ids.Set( face.MatID, true );
		return material_ids.ToArray();
	csharpProvider = dotnetobject "Microsoft.CSharp.CSharpCodeProvider"
	compilerParams = dotnetobject "System.CodeDom.Compiler.CompilerParameters"
	compilerParams.ReferencedAssemblies.Add("System.dll");
	compilerParams.ReferencedAssemblies.Add((getdir #maxroot) + "Autodesk.Max.dll");
	compilerParams.GenerateInMemory = on
	compilerResults = csharpProvider.CompileAssemblyFromSource compilerParams #(source)
	if (compilerResults.Errors.Count > 0 ) then
		local errs = stringstream ""
		for i = 0 to (compilerResults.Errors.Count-1) do
			local err = compilerResults.Errors.Item[i]
			format "Error:% Line:% Column:% %\n" err.ErrorNumber err.Line err.Column err.ErrorText to:errs
		format "%\n" errs
		undefined
	local assembly = compilerResults.CompiledAssembly.CreateInstance "MeshMaterialIDs"
	global GetUsedMtlIDs = assembly.GetUsedMtlIDs
-- use it like this
GetUsedMtlIDs $.inode.handle
jahman, you rock! i tried it out on a 4.000.000 tri object and take 1 second! fantastic, thanks a lot!
furthermore it works on edit poly and edit mesh as well
Reply to Matyrix
Panteleev Sergey
Glad to hear that. It should work ok with anything convertible to mesh.
upd
Here're my numbers :)
Numfaces 4224000
Time: 0.293sec. Mem: 544L
Unsafe Time: 0.058sec. Mem: 544L
Vojtech Cada
That only shows when MultiSubObject material is assigned (and only would display all the ids if the multimaterial had the right number of matching id materials).
Reply to Vojtech Cada
Matyrix
Yes, you are right. When you have more very high detailed objects, it's the fastest way to drop a multi material to the objects with 100+ sub material, and read the ID-s, and restore the materials - instead of check every face with ID information.
Reply to Matyrix
Vojtech Cada
For personal use where you're pretty sure you don't exceed that, I agree; for a production-ready tool, you'd need 65536 submaterials (some pipelines use fixed id per material). But unless you're working with extra dense meshes, getting the ids used by ~10k mesh shouldn't take more than tenth of a second anyway.
Panteleev Sergey
There's also <IGameMesh>.GetActiveMatIDs method available, but unfortunately I couldn't find a way to use it from maxscript.
Wow, i think this is the right way, thanks!
It should be work somehow... I will read about it, hope can solve.
Reply to Matyrix
Vojtech Cada
	local compilerParams = dotNetObject "System.CodeDom.Compiler.CompilerParameters" #(
		"System.dll", "System.Core.dll", getDir #maxRoot + "Autodesk.Max.dll",
		getDir #maxRoot + "\bin\assemblies\Autodesk.Max.Wrappers.dll")
	local compilerResults = (dotNetObject "Microsoft.CSharp.CSharpCodeProvider").CompileAssemblyFromSource compilerParams #(
		"using System;
		using System.Linq;
		using Autodesk.Max;
		using Autodesk.Max.Wrappers;
		internal static class TabExtensions {
			public static IEnumerable<T> ToEnumerable<T>(this ITab<T> tab) {
				for (int i = 0; i < tab.Count; i++)
					yield return tab[i];
		class Poly {
			internal static readonly IGlobal Global = GlobalInterface.Instance;
			public static int[] GetSelectedObjMatIDs() {
				var pIgame = Global.IGameInterface;
				pIgame.InitialiseIGame(true);
				pIgame.SetStaticFrame(0);
				using (var currNode = Global.COREInterface.GetSelNode(0))
				using (var gameNode = pIgame.GetIGameNode(currNode))
				using (var gameMesh = Global.IGameMesh.Marshal((gameNode.IGameObject as Autodesk.Max.Wrappers.IGameObject).INativeObject__NativePointer)) {
					return gameMesh.InitializeData ? gameMesh.ActiveMatIDs.ToEnumerable().Select(id => id + 1).ToArray() : new int[0];
	::poly = compilerResults.CompiledAssembly.CreateInstance "Poly"
if selection.count == 1 and isKindOf $ GeometryClass do Poly.GetSelectedObjMatIDs()
Panteleev Sergey
Thanks a million Vojtěch.
I couldn't run it in 2014 (Global.IGameMesh is absent), but in 2016 works just fine. But it is surprisingly slow compared to what I've posted above. 4kk mesh processed in about 9-10sec
Reply to Panteleev Sergey
Vojtech Cada
Yeah, IGameMesh is more about convenience than speed, though I wouldn't have expected it to be that slow either. That sounds like even snapshotAsMesh+getFaceMatID in maxscript would be faster.
Matyrix
This tool works for specific workflow, you are right it's not a production-ready tool for everybody. Just for personal workflow.
One object is 5-10.000.000 polygon unfortunately.
