get properties to display in a UI??
By jdigital · 2008-12-07
I've been trying to figure this out and can't find this information anywhere in the help to point me in the right direction.
Basically I want to be able to create a Floating Dialog that could read the selected object properties.
So example, lets say i have a box. I want to read the "Height" value and display it in this floating UI.
I can certaily easily selection objects and chagne their values in mass but getting their current settings to be input into a dialog box seems hard to find the right info.
The main idea is to have a script that I could run when I select a bunch of objects and it would build a floating dialog box with spinners for each objects values. Of course I'd control which properties of the objects I'd want to read.
I hope this makes sense to someone.
dimwalker
For one box it can look somehow like this:
mybox = box()
mybox.name = "TestBox"
select mybox
curr_h = mybox.height
rollout boxh "box height"
spinner box_h "Height :" range:[0,1000,curr_h] type:#integer
on box_h changed val do $.height = val
CreateDialog boxh
