Under help for ActionMans it states here under is checked: http://help.autodesk.com/view/3DSMAX/2016/ENU/?guid=__files_GUID_D33B403…
that:
.isChecked : boolean : Read
Contains the Checked state of the ActionItem as determined by its isChecked event handler.
Why does it not recognise any enabled button.
Say for instance you open up SME>Click a node>Hide unsed node.
So that enables the button. Surely when you run the code below it should be listed as enabled.
Thanks for any help with this. Perhaps a bug lies here. I'm using max 2016. OR do I have to somehow get the hwnd of the SME too?
clearlistener()
sme.open()
for i = 1 to actionMan.numActionTables-1 where (actionMan.getActionTable i).name == "SME" do
atbl = actionMan.getActionTable i
format "% ID:% Name:'%' ContextID:% ContextName:'%' NumActionItems:%\n" i atbl.id atbl.name atbl.contextID atbl.contextName atbl.numActionItems
for j = 1 to atbl.numActionItems do
aitm = atbl.getActionItem j
aitm.getDescription &desc
chkd = aitm.isChecked
aitm.getCategory &cat
aitm.getButtonText &btn
aitm.getMenuText &mnu
hasicon = aitm.hasIcon()
if hasicon then
aitm.getIconFileName &iconfile
iconfile = filenamefrompath iconfile
iconindex = aitm.getIconIndex()
format "\t% ID:% Desc:'%' IsChecked:'%' Cat:'%' BtnTxt:'%' MnuTxt:'%' Icon:[%,%] \n" j aitm.id desc chkd cat btn mnu iconfile iconindex
format "\t% ID:% Desc:'%' IsChecked:'%' Cat:'%' BtnTxt:'%' MnuTxt:'%'\n" j aitm.id desc chkd cat btn mnu
Bump
