get descendant bitmap of diffuse input
By michael · 2018-08-22
Whats the best way to get the first descendant bitmap of a material's diffuse property?
So for example if the diffuse has bitmap plugged into a color correction node, which in turn is plugged into a mix map, how would I find the bitmap? Would I need to loop through each parameter of each child, and then the childs child and so on?
Panteleev Sergey
getClassInstances bitmapTexture target:$.material.diffusemap
brilliant
That's great, thanks for the info.
here's the usage incase it's useful to anyone. It returns an array of all bitmapTexture maps plugged into the redshift diffuse_color_map parameter.
fn GetTheBitmapsFromTheTree Diff =
return getClassInstances bitmapTexture target:Diff
--main function
Sel = selection as array
count = 0
for TheGeo in Sel do
if classof TheGeo.material == Multimaterial then
--print(“multisub \n”)
for m = 1 to TheGeo.material.numsubs do
connectedToMultiMat = TheGeo.material[m]
if classof connectedToMultimat == Subanim do continue
c = classof connectedToMultimat as string
else(
--gets the full array of maps
--print (ReadAllMaps(TheGeo.Material))
--gets just the specified map
--ListPropsAndValues(TheGeo.Material)
TheBitmaps = #()
TheBitmaps = GetTheBitmapsFromTheTree(TheGeo.Material.diffuse_color_map)
cnt = 0
for bitmap in TheBitmaps do
print(bitmap)
cnt = cnt + 1
Reply to michael
Two advices:
1- put your code inside
["code"]
-- your code
["/code"].
Do not type the quotes. :)
2- do not use "return" when you want the function to return what it have to return. In maxscript, most of the time, all functions returns the last expression/variable.
