Get data from Attribute_Holder params in array
By Vugar · 2012-06-10
How to get(collect) data from Attribute_Holder params in array for set another similar Attribute_Holder?
Thanks in advance)
Comments (10)
Vugar
It work )))
I learned a code from barigazy and maxscript help )))
And finally we got this code )))
obj_A = $
obj_B = $
for i = 1 to 2 do -- Rollouts count
	CA_GMod = (custAttributes.get obj_A.modifiers[1] i) -- Attrib Rollout For Get
	propsNamesArr = getPropNames (CA_GMod) -- Get Attrib Rollout Name To Array
	propsValuesArr = for n in propsNamesArr collect (getproperty CA_GMod n) -- Get Attrib Rollout Val To Array
	-- Set Param Roll To Roll custAttributes A To custAttributes B
	CA_SMod = (custAttributes.get obj_B.modifiers[1] i) -- Attrib Rollout For Set
	for n = 1 to propsNamesArr.count do
		setproperty CA_SMod propsNamesArr[n] propsValuesArr[n]
Thanks to barigazy for participating in the subject!
Try this code
local propsNamesArr = #()
local propsValuesArr = #()
fn getCAPropsValue obj &propsNamesArr &propsValuesArr = if obj.modifiers.count > 0 do
local propsValues
local objModsArr = for m in obj.modifiers collect (classof m)
local idx = finditem objModsArr EmptyModifier
if idx != 0 do
local CA_Mod = obj.modifiers[idx].Custom_Attributes
propsNamesArr = getPropNames (CA_Mod)
propsValuesArr = for i in propsNamesArr collect (getproperty CA_Mod i)
fn setCAPropsValue obj namesArr valsArr = if obj.modifiers.count > 0 do
if idx != 0 do
for n in 1 to namesArr.count where isProperty CA_Mod namesArr[n] do setproperty CA_Mod namesArr[n] valsArr[n]
getCAPropsValue $Box02 &propsNamesArr &propsValuesArr
if propsNamesArr.count != 0 do setCAPropsValue $Box01 propsNamesArr propsValuesArr
Think I'm close to a find code :)
Think I'm close to a find code after minor changes :)
propsNamesArr = getPropNames (custAttributes.get $.modifiers[1] 1)
propsValuesArr = for i in propsNamesArr collect (getproperty $.modifiers[1] i)
Vugar
The script works fine, but it's not exactly what I needed because it simply prints the structure and I need an array with the current value of the selected object Attribute_Holder interface.
Perhaps the proposed script will solve my problem but I do not understand how (((
Here's my simple method that does what I need, but I'm sure that is not good script, and dont elegant method )))
-- Creates an array of current values of an object with Attribute_Holder modifier
CAV = #($.modifiers[#Attribute_Holder].Custom_Attributes[1].value,$.modifiers[#Attribute_Holder].Custom_Attributes[2].value)
#(63.4061, 31.703)
-- Apply the resulting array of data to another object with  similar Attribute_Holder modifier
for i = 1 to 2 do
    $.modifiers[#Attribute_Holder].Custom_Attributes[i].value = CAV[i]
I've attached a file which I tested it
Thank you again, and sorry my english
Hope this help
This is an example by Anubis (slightly modified by me)
and represent mapped fn which will extract all parameterblock data from a custom attribute (at object level or modifier).
extract parameterblock data from a custom attribute
mapped fn custAttribute_showPBlockDefs obj modName: =
format "%\n" obj.name
local getDefs = if modName != unsupplied then custAttributes.getDefs obj.modifiers[modName] else custAttributes.getDefs obj
for objDef in getDefs do
format "\t%\n" objDef ; format "\tname: %\n" objDef.name ; format "\tattribute id: %\n" objDef.attribID
format "\tParameter Blocks:" ; pbArray = custAttributes.getPBlockDefs objdef
for a = 1 to pbArray.count do
itms = pbArray[a] ; format "\n\t\tname = %\n" itms[1] ; format "\t\tid = %\n" itms[2]
format "\t\towners reference number = %\n" itms[3] ; keywordParams = itms[4] ; format "\t\tparameter block keywords:\n"
for x = 1 to keywordParams.Count/2 do (format "\t\t\t% = %\n" keywordParams[x] keywordParams[x+1] ; x = x+1) ; format "\t\tparameters:"
for y = 5 to itms.Count do
format "\n\t\t\t#name = %\n" itms[y][1]
for z = 1 to itms[y][2].Count by 2 do (format "\t\t\t% = %\n" itms[y][2][z] itms[y][2][z+1])
--if you want to extract params from modifier just
--uncomment "modname" and set modifier name
custAttribute_showPBlockDefs $ --modName:#Attribute_Holder
