Get ClassInstances bitmaptex didnt catch the texture
By fajar · 2012-12-20
hey everyone Im working on script asset management ...I got it all working till I got ClassInstances bitmaptex didnt work with arch_mi material....is there any way to retrieve same result as getclassinstances bitmaptex....raw data that contain all hidden data
btw im workin on max 9 tho....all vraymtl working if i assign texture map to it. the map cathced using getclass instance.
#(Map #2:Bitmap, Map #hall:Bitmap)
somthing like that.
thanks
fajar
solution
Hi fajar ,
maybe this can help
clearlistener()
mapsArr=#()
fn getMtlMaps mtl maps =
if mtl != undefined and mtl.numsubs != 0 do
for m = 1 to mtl.numsubs where (mtl[m] != undefined) do
if (isKindOf mtl[m] SubAnim) and (isKindOf mtl[m].Object textureMap) do append maps mtl[m].Object
getMtlMaps mtl[m] maps
getMtlMaps $.material mapsArr
mapsArr
--for i in mapsArr do print i.filename
usedMaps()
and
enumerateFiles()
are useful if you need an array with bitmap's filenames (Strings), but not helps to collect instances of BitmapTex objects.
Reply to Panayot Karabakalov
zahid hasan
i see,after reading your post i just realized how different they are.
though its getting my job done.i just need to collect bitmap texture.
zahid hasan
i am using max 2012 and same problem.specially some vray material and displacement related maps are not found.
so i am using usedmaps() instead.
fajar
hehhehhee.....damn...why they? duh....
thanks for the info anubis.
you're in trouble then
as until Max 2011 (where it was fixed) getClassInstances cannot collect all nested class instances.
