function for stretchy bones
By marcoslm · 2016-04-19
Hi, everyone
I am new in maxscript and I want to create a stretchy leg. I have made a function, it works very well, but when I restart 3dsmax, I have many of errors. I need help, please. Here is the code:
--freeze transform as function
fn FreezeTransformA item =
local CurObj = item
if classof CurObj.rotation.controller != Rotation_Layer do
-- freeze rotation
CurObj.rotation.controller = Euler_Xyz()
CurObj.rotation.controller = Rotation_list()
CurObj.rotation.controller.available.controller = Euler_xyz()
-- "Localization on" --
CurObj.rotation.controller.setname 1 "Frozen Rotation"
CurObj.rotation.controller.setname 2 "Zero Euler XYZ"
-- "Localization off" --
CurObj.rotation.controller.SetActive 2
if classof CurObj.position.controller != Position_Layer do
-- freeze position
CurObj.position.controller = Bezier_Position()
CurObj.position.controller = position_list()
CurObj.position.controller.available.controller = Position_XYZ()
CurObj.position.controller.setname 1 "Frozen Position"
CurObj.position.controller.setname 2 "Zero Pos XYZ"
CurObj.position.controller.SetActive 2
-- position to zero
CurObj.Position.controller[2].x_Position = 0
CurObj.Position.controller[2].y_Position = 0
CurObj.Position.controller[2].z_Position = 0
--FreezeTransform $
select $*
for i in selection do
freezeTransformA i
-- Create IK solver
ptA = point box: on name:"ThighUp" cross:off
ptB =point box: on name:"ThighDown" cross:off
$thighup.pos = $bone001.pos
$thighDown.pos = $bone003.pos
$bone001.parent = $thighUp
ab = IKSys.ikChain $bone001 $bone003 "IKHISolver"
ab.name = "ikleg"
$ikleg.transform.controller.goalSize = 10
$thighDown.parent = $Ikleg
Function StretchyBonesLegs Bone01 Bone02 Bone03 PointA PointB =
-- store lengths of bones
LengthA = Bone01.length
LengthB = Bone02.length
total = LengthA + LengthB
bone02.pos.controller.Zero_Pos_XYZ.controller.X_Position.controller = float_script()
bone02.pos.controller.Zero_Pos_XYZ.controller.X_Position.controller.AddNode "pointA" PointA
bone02.pos.controller.Zero_Pos_XYZ.controller.X_Position.controller.AddNode "pointB" PointB
bone02.pos.controller.Zero_Pos_XYZ.controller.X_Position.controller.script =
"total = LengthA + LengthB
dist = (distance pointA pointB)
if dist > total then (
xPos = ((dist - total)/2)
) else (
xPos = 0)"
bone03.pos.controller.Zero_Pos_XYZ.controller.X_Position.controller = float_script()
bone03.pos.controller.Zero_Pos_XYZ.controller.X_Position.controller.AddNode "pointA" PointA
bone03.pos.controller.Zero_Pos_XYZ.controller.X_Position.controller.AddNode "pointB" PointB
bone03.pos.controller.Zero_Pos_XYZ.controller.X_Position.controller.script =
dist = (distance PointA PointB)
) else (
xPos = 0)"
StretchyBonesLegs $Bone001 $Bone002 $Bone003 $ThighUp $ThighDown
Thank you very much
Marcos Meneghetti
4698to
e
-- $thighDown.parent = $Ikleg
$Ikleg.parent = $thighDown
Julien Plard
the main problem is when you store the length of each bone. Your variables LengthA and LengthB are created only when you use StretchyBonesLegs the first time. When the scene is reloaded, they don't exist anymore. You should store them the same way you store pointA and PointB, with addnode, then access the length from your floatscript. That way, they will be accessible all the time, even if you change the name of your bones.
There was a a weird rotation of the Ik bones when i restarted, so I aligned $thighup with the first bone.
fn FreezeTransform item = --Apply a freeze transform on selected items
	local CurObj = item
		-- freeze rotation
		/* "Localization on" */
		/* "Localization off" */
		-- freeze position
		-- position to zero
	return true
fn Start =
	-- Create IK solver
	$thighup.transform = $bone001.transform
	BonesList = for i in $Bone001 collect i
	select BonesList
	FreezeTransform i
	-- Create IK solver
	ab.name = "ikleg"
Start()
fn StretchyBonesLegs target Bone01 Bone02 PointA PointB =
	local boneCtrl = target.pos.controller.Zero_Pos_XYZ.controller.X_Position.controller = float_script()
	boneCtrl.AddNode "pointA" PointA
	boneCtrl.AddNode "pointB" PointB
	boneCtrl.AddNode "Bone01" Bone01
	boneCtrl.AddNode "Bone02" Bone02
	boneCtrl.script =
	"total = Bone01.length + Bone02.length
	) else (
	xPos = 0)"
StretchyBonesLegs $Bone002 $Bone001 $Bone002 $ThighUp $ThighDown
StretchyBonesLegs $Bone003 $Bone001 $Bone002 $ThighUp $ThighDown
I optimized your code a little.
It works but if you want to scale the whole armature, make sure you multiply your distances by that scale value in your script, otherwise it will be broken.
