thanks for help (again)
but I have some problems with max. When you make too much errors in listener,
after a while nothing works,... I need to reboot max...
Sometimes if you forget to close brucket of your code max will not print the result.
Try to ** interrupted ** max with Escape key.
If you this not help then you have srious problem. Reset max as usual
Because print can have only one argument. :)
Yep.
Kostadin explain why.
And if you want advanced debagging fn (with more arguments input) you can use *format* fn. I suppose you already know that. :)
You need to add brackets like this
:)Try to ** interrupted ** max with Escape key.
