Hello,
Is it even possible to have a floating smoothing group menu that works for Editable Mesh Objects? I know poly is generally the king of smoothing, but I was hoping someone had discovered a way to get a nice floating Smoothing groups menu that works on Editable Mesh Objects.
Hi Matthew,
Here is a link:
https://www.mediafire.com/file/2nui3bfd2ayn7an/Floating_SmoothingGroup.m…
The script works on Editable Mesh and Editable Poly, for EditPoly modifiers i cheated a little, it will open the built-in function instead.I didn't add EditMesh support,and it works only on one object at a time, another limitation is that, if the script is already opened when you create a new object the UI won't be well updated,in this case just restart the script.
for installation the category is "SimonScripts"
Cheers,
Simon
Why not asking the author of PolySmoother to add Editable Mesh support?
https://www.polytools3d.com/tools/polysmoother/
