Hello.
I'm embarking on a script writing/learning mission and asked the guys i worked with for some ideas for a script for me to make.
One came up with a good one which would be useful. He basically suggested a script that can seach a folder on our network that contains maxfiles and it would list whether a certain maxfile has a certain type of object within it and it would show you the maxfile name and the object you were searching for.
For instance any maxfile that has a VrayPlane or a VraySun object within it.
It would be similar to a merge type script that lists the objects in a closed maxfile, but it would only show what was requested and the maxfiles they were in.
Is this doable in a maxscript?
Loading .max files
Yep, as i said, no way to get the class of any object without merging, in other words, merge (or open) the scene files and scan the objects is the existing alternate.
I think it's above my capabilities to script this for now!
More basic simple learning scripting for me.
No way of doing it then?
Hi Anubis.
So from what you've put it's not possible to search for a particular object....
Boo hoo!
Thanks for the input Anubis, at least it's potentially saved me a headache of trying to do something that's impossible at the moment.
I don't think there are alternate ways of achieving what i want are there?
With
function you can get a list of objects names (array of strings) in a scene file but no way to get their 'type' (class) w/o merging.
