Hi Guys -
I am looking to add on to this code to add only select if multimaterial has standard material in .materialList[]
select (for i in objects where (classof i.mat == multimaterial) collect i)
Thank you.
By Ash Mohammed · 2014-06-29
Hi Guys -
Thank you.
Comments (8)
U can define filter FN that can be used like this
fn filterMultiStd mtl = isKindOf mtl Multimaterial and (for m in mtl.materialList where isKindOf m Standard collect m).count != 0
for o in objects where filterMultiStd o.mat collect o
Thank you!
In case anyone wants this. This might come in handy for anyone working with VRay Scene and trying to remove Standard or Architectural Material from your scene. This script will help you find / select objects with non VRay Materials.
Cheers
Not tested but simplified version
try(destroyDialog ::SelectionTool)catch()
rollout SelectionTool "Selection Tool" width:162 height:110
radiobuttons rb_mtlTypes "Material Types:" labels:#("Standard Mtl", "Architectural Mtl", "Arch&&Design Mtl") pos:[5,5]
checkbox cb_multimat "Consider Also Multi/Sub Mtl" pos:[5,70] checked:on
button btn_doit "DO IT!" pos:[105,5] width:50 height:60
fn filterMultiStd mtl class: considerMMtl: =
if not considerMMtl then isKindOf mtl class else
isKindOf mtl class or (isKindOf mtl Multimaterial and (for m in mtl.materialList where isKindOf m class collect m).count != 0)
on btn_doit pressed do
material = case rb_mtlTypes.state of
1: Standard
2: Architectural
3: Arch___Design__mi
select (for m in objects where m.mat != undefined and (filterMultiStd mtl class:material considerMMtl:cb_multimat.checked) collect m)
createDialog SelectionTool 160 90 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
Clean
I am unable to get it to work though.
!this is way more simplified then what i had!
What cause the problem?
not really sure
its not giving any errors.....
radiobuttons rb_mtlTypes "Material Types:" labels:#("Standard Mtl", "Architectural Mtl", "Arch&&Design Mtl") pos:[5,5] fieldwidth:50
fn filterMultiStd mtl class: considerMMtl:cb_multimat.checked =
1: Standard
2: Architectural
select (for m in objects where m.mat != undefined and (filterMultiStd m.mat class:material) collect m)
Worked!
