False Algorithm
By Alex · 2013-05-11
Hey ! I need help again ! I've finish my algorithm !!!! :D no error for run
But Attach_all_mesh and EXPORTATION are failed
Attach_all_mesh nothing happened
EXPORTATION 3ds max say me : --No ""+"" funtion for undefined in line 47
exportFile (exportfolderASE + (getFilenameFile maxFileName)+ suff + ".ase") #noPrompt
And the algorith :
----------------------------------------------------------------------------------------------------------------------------------- FUNCTION ----------------------------------------------------------------------------------------------------------------------------
function Attach_all_mesh =
			-------------- ATTACH ALL MESH 	--------------
					max select all
					mtl = #() ; tmp = #() ; fin = #()
					sel = selection as array
					if sel.count == 0 then -- check selection
						messageBox "Erreur lors de l'execution du script s'il vous plait contactez Kasimashi"
					(	-- filter selection
						sel = for i in sel where classOf i == Editable_mesh \
							and i.material != undefined collect i
							messageBox "Aucun Mesh dans la séléction !!! " title:"Attacher les Mesh"
							for i in sel do
								appendIfUnique mtl i.material
							for m in mtl do
								tmp = for i in sel where i.material == m collect i
								append fin tmp
							undo on
								for i in fin do
									trg = i[1]
									deleteItem i 1
									for j in i do
										meshop.attach trg j attachMat:#IDToMat condenseMat:true
							$.name = "Model"-
							$.pos = [0,0,0]
-----------------------EXPORT SUFF ---------------------------------------
function EXPORTATION suff=
------------------- SCALE 1/88 FOR FREEWORLD LUNASTRA------------------------
						-----------------------EXPORT GR2 + 3DS -----------------------
	scale $ [88,88,88]
	actionMan.executeAction 0 "311"  -- Tools: Zoom Extents All Selected
	saveMAXFile (exportfolder3DSMAX+ (getFilenameFile maxFileName) + suff + ".max")
	exportFile (exportfolder3DS +(getFilenameFile maxFileName)+ suff + ".3ds") #noPrompt using:exporterPlugin.classes[1]
	exportFile (exportfolderGR2 +(getFilenameFile maxFileName)+ suff + ".gr2")
-----------------------PLANE OVER FACE ---------------------------------------
function planesOverFaces obj orient =
					local planeArr = #()
					local ev = polyop.getEdgeVerts
					local gv = polyop.getvert
					local gfe = polyop.getFaceEdges
					local gfsc = polyop.getSafeFaceCenter
					local gfn = polyop.getFaceNormal
					local allFaces = (obj.Faces as bitarray) as array
					for f in allFaces do
						getEdges = gfe obj f
						local sizeArr = #()
						for i in getEdges do
							append sizeArr (distance (gv obj (ev obj i)[2]) (gv obj (ev obj i)[1]))
						if orient == 0 then
						(w = amin sizeArr ; l = amax sizeArr)
						(l = amin sizeArr ; w = amax sizeArr)
						fc = gfsc obj f
						nf = gfn obj f
						xv = normalize (cross nf [0,0,1])
						yv = normalize (cross nf xv)
						thePlane = plane length:l width:w lengthsegs:1 widthsegs:1 name:(uniquename "collision_plane_")\
						isSelected:on wirecolor:(random black white) transform:(matrix3 xv yv nf fc)
						append planeArr thePlane
					select planeArr
-----------------------CREATE BOX AS CAGE ---------------------------------------
function createBoxAsCage obj = if isValidNode obj do
					local bb = in coordsys local nodeLocalBoundingBox obj
					local wX = abs((bb[1]-bb[2]).x) , lY = abs((bb[1]-bb[2]).y) , hZ = abs((bb[1]-bb[2]).z)
					local cage = convertToPoly (box width:wX length:lY height:hZ mapcoords:on name:"Cage" wirecolor:black)
					CenterPivot cage
					local tm = obj.transform
					tm.row4 = obj.center
					cage.transform = tm
					polyop.deleteFaces cage #{1,2}
					planesOverFaces cage (if wX < hZ then 0 else 1)
					delete cage
-------------------------------------------------------------------------------------------------------------------- DEBUT ALGORITHME ----------------------------------------------------------------------------------------------------------------------
rollout bgaRoll "Lunastra Building Compiler • • •"
		local allFiles = #()
		label Help_1 "-------------------------------------------------------------------------------" align:"center"
		label Help_2 "Veuillez séléctionner votre répertoire contenant tout vos modèles à exporter" align:"center"
		label Help_3 "Ensuite cliquez sur le button exporter standard ou détruit suivant ce que vous voulez" align:"center"
		button btn_import "Selection du dossier" align:"center"
		label Help_4 "-------------------------------------------------------------------------------" align:"center"
		button btn_export_standard "Exporter Standard" align:"center"
		button btn_export_destroy "Exporter Détruit" align:"center"
		label Copyright "Create by Kasimashi for any problem contact : Kasimashi@hotmail.com" align:"center"
		on btn_import pressed do
			dir = getSavePath caption:"Select Folder" initialDir:#images
				 if dir != undefined do
					allFiles = getFiles (dir + "\\*.max")
					print allFiles
					-------------------------------- DECLARATION DES VARIABLES ---------------------------
					exportfolderASE = dir  + "\\" +"ASE"+"\\"
					exportfolderGR2 = dir  +  "\\" + "GR2"+"\\"
					exportfolder3DS = dir  +  "\\"+ "3DS"+"\\"
					exportfolder3DSMAX = dir  + "\\"+ "3DSMAX"+"\\"
					---------------------- CREATION DES REPERTOIRES S'IL N'EXISTE PAS ---------------
					if doesFileExist exportfolderASE  == false do (makedir exportfolderASE)
					if doesFileExist exportfolderGR2  == false do (makedir exportfolderGR2)
					if doesFileExist exportfolder3DS  == false do (makedir exportfolder3DS)
					if doesFileExist exportfolder3DSMAX  == false do (makedir exportfolder3DSMAX)
		on btn_export_standard pressed do
			for f in allFiles do
					loadMAXFile f;
					max select all --select all objects
					delete (for o in objects where matchPattern o.name pattern:("*2_*") collect o)
					Attach_all_mesh
					$selection.material = meditMaterials[1] --assign standard material
					$selection.wirecolor = black -- assign black color of wireframe
					viewport.SetRenderLevel #smoothhighlights
					EXPORTATION ""
		on btn_export_destroy pressed do
					loadMAXFile f;
					delete (for o in objects where matchPattern o.name pattern:("*2_*") and o.parent != undefined collect o.parent)
					Attach_all_mesh
					EXPORTATION "_destroyed"
--------------------------------------------------------------------------------------------------------------------- FIN ALGORITHME ----------------------------------------------------------------------------------------------------------------------
createDialog bgaRoll 500 200 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
This works, but I think that 3dsMax don't know how to export as .gr2 and only the GR2 folder is empty.
		local exportfolderASE = undefined
		local exportfolderGR2 = undefined
		local exportfolder3DS = undefined
		local exportfolder3DSMAX = undefined
			max select all
					for i in sel do
					for m in mtl do
						append fin tmp
					undo on
						for i in fin do
							trg = i[1]
							deleteItem i 1
							for j in i do
					$.name = "Model"
					$.pos = [0,0,0]
			scale $ [88,88,88]
				local sizeArr = #()
				if orient == 0 then
				fc = gfsc obj f
				nf = gfn obj f
			select planeArr
			CenterPivot cage
			cage.transform = tm
			delete cage
				print allFiles
				loadMAXFile f;
				Attach_all_mesh()
				EXPORTATION ""
					loadMAXFile f;
					Attach_all_mesh()
The problem again is the variables and where you defines them. Try this:
		local exportfolderASE = dir  + "\\" +"ASE"+"\\"
		local exportfolderGR2 = dir  +  "\\" + "GR2"+"\\"
		local exportfolder3DS = dir  +  "\\"+ "3DS"+"\\"
		local exportfolder3DSMAX = dir  + "\\"+ "3DSMAX"+"\\"
						max select all
								for i in sel do
								for m in mtl do
									append fin tmp
								undo on
									for i in fin do
										trg = i[1]
										deleteItem i 1
										for j in i do
								$.name = "Model"-
								$.pos = [0,0,0]
			scale $ [88,88,88]
				local sizeArr = #()
				if orient == 0 then
				fc = gfsc obj f
				nf = gfn obj f
			select planeArr
			CenterPivot cage
			cage.transform = tm
			delete cage
		on bgaRoll open do
				print allFiles
					loadMAXFile f;
					Attach_all_mesh
					EXPORTATION ""
					loadMAXFile f;
					Attach_all_mesh
Keep the functions inside the rollout, otherwise they will become global. Did you read the Scope of variables topic in the maxscript help file?
Reply to miauu
Alex
Don't work :(MAXLISTENNER
Don't work :(
MAXLISTENNER say me :
-- Compile error: Undeclared variable:  dir
--  In line: 		local exportfolderASE = dir  +
Without this error Attach all mesh don't work again :(
I've try to remake my script now this script work :p Edit : It had work 1 time now don't work but I've don't edit something in the script is strange !
		button btn_export "Export" align:"center"
				print allFiles
			exportfolderASE = dir + "\\ASE\\"
			exportfolderGR2 = dir + "\\GR2\\"
			exportfolder3DS = dir + "\\3DS\\"
			exportfolder3DSMAX = dir + "\\3DSMAX\\"
on btn_export pressed do
	for f in AllFiles do
	loadMAXFile f;
					max select all
							for i in sel do
							for m in mtl do
								append fin tmp
							undo on
								for i in fin do
									trg = i[1]
									deleteItem i 1
									for j in i do
							$.name = "Model"
							$.pos = [0,0,0]
			exportFile (exportfolderASE + (getFilenameFile maxFileName)+ ".ase") #noPrompt
			scale $ [88,88,88]
			max tool zoomextents all
			saveMAXFile (exportfolder3DSMAX+ (getFilenameFile maxFileName)+ ".max")
			exportFile (exportfolder3DS +(getFilenameFile maxFileName) +".3ds") #noPrompt using:exporterPlugin.classes[1]
			exportFile (exportfolderGR2 +(getFilenameFile maxFileName)+".gr2")
	clearselection()
Thanks for your help !
Regards
Kasimashi
