Hello!
I would like to know if is possible to execute a script as an argument of command line or something similar.
I have to execute a script over several scenes and it would be very useful for me if I could do that without copying the script in startup or stdscripts folder because I will need do that many times and many others I will need the default behaviour when I start MAX
Thanks!
Hi - this is the commandline I use:
3dsmax -U MAXScript yourscripthere.ms -mip -slient
Which is supposed to launch Max in a UI-minimized mode, and run "yourscripthere.ms" as soon as it launches.
In the maxscript itself, I then get a directory listing of the max files that I want to process, and iterate through them, opening each max file and processing it as needed.
hope this helps.
-Glen.
Thank you very much, that works
