Evaluation of my beginner script...
By K · 2011-10-14
Hi everyone, I have been trying to put a script together that builds random favela type geometry in a stepped manner as if on a hillside. I will include the script and a picture.
I know the script is awful but I am willing to embarass myself in the name of learning:) Would really appreciate any help you guys can offer in terms of devloping it for the better :)
Thanks for your time :)
Script:
Favela = box length:10 width:10 height:10
-- Create 5 iteration along the Y Axis
for i = 1 to 5 do
box_copy = copy Favela
box_copy.pos = [0, i*20, 0]
select objects
macros.run "Modifier Stack" "Convert_to_Poly"
-- attach Objects, Courtesy of Chris Gray, CG Society
while selection.count > 1 do
selcount = selection.count
for i = selcount to 2 by -2 do
polyop.attach selection[i] selection[i-1]
update selection[1]
select objects
for i = 1 to 5 do
box_copy = copy $
box_copy.pos = [i*20,0,i*20]
--Select Box and Move to position 0,0,0
select $Box006
$.position = [0,0,0]
select objects
-- Attach objects, Courtesy of Chris Gray, CG Society
update selection[1]
-- Select Sub-Object level: Polygons
subobjectLevel = 4
-- Select Random Faces
PolyToolsSelect.Random 1 60 0 false
-- Extrude Selected Faces
$.extrusionType = 2
$.faceExtrudeHeight = 10
$.EditablePoly.buttonOp #Extrude
select objects
-- Select by normal -Z
polyToolsSelect.Normal 3 90 true
-- Inset selected faces
$.insetType = 1
$.insetAmount = 3.93701
$.EditablePoly.buttonOp #Inset
-- Extrude selected faces
$.faceExtrudeHeight = 19.685
-- Delete selected faces
actionMan.executeAction 0 "40020"
max delete
$.EditablePoly.delete #Face
Mark Beckitt
Nice little script, thanks for sharing
