Hi. I want to make a script that moves selected clusters in the unwrap modifier with multiple objects selected.
I already have a script that does that but with only one object selected
$.modifiers[#unwrap_uvw].unwrap2.MoveSelected [1.0,0,0]
but when i try to apply that when multiple objects are selected i get problems.
sel = selection
obj = #()
sel.modifiers[#unwrap_uvw].unwrap2.getSelectedFaces ()
sel.modifiers[#unwrap_uvw].unwrap2.moveSelected [1.0,0,0]
i get this error
-- Unknown property: "modifiers" in $selection
What am i doing wrong?
Thanks!
I have found a solution to my problem and it kinda goes like this
selectionSets["tempSel"] = selection
sel = selection
obj = #()
for i in sel do
append obj i
for i = 1 to obj.count do
select obj[i]
obj[i].modifiers[#unwrap_uvw].unwrap.edit ()
obj[i].modifiers[#unwrap_uvw].setTVSubObjectMode 3
face = obj[i].modifiers[#unwrap_uvw].getSelectedFaces
obj[i].modifiers[#unwrap_uvw].unwrap2.MoveSelected [0,-1,0]
clearSelection()
select selectionSets["tempSel"]
for i in sel do
i.modifiers[#unwrap_uvw].unwrap.edit ()
i.modifiers[#unwrap_uvw].setTVSubObjectMode 3
If anyone knows a better way to do exactly this i am open for suggestions :)
I had a script that does something like that, puts it in a loop but it didn't work well
sel = selection
obj = #()
for i in sel do
i.modifiers[#unwrap_uvw].unwrap2.MoveSelected [1.0,0,0]
But this script depends on how many objects i have selected. For example if i have 3 objects selected it moves the selected clusters 3UV tiles. If i have 6 objects selected it moves the selected clusters 6 times. But i want to move only one tile when lots of objects are selected. Thats the point of the whole script.
Is there some way not to loop through objects but to treat the selected objects as one?
i am max-less right now so can not test but i think you cant put modifiers on the selection that is the object "array" at this point. you should loop through your objects that are in the selection.
also sometimes the operations you are doing while looping let max loose the selection so i would recommend to store the selection as extra array and loop through the new "safe" selection-array.
hope this helps a bit.
