Error when used with more then one object
By titane357 · 2021-11-24
I tried to make a script to "Freeze" some objects:
I have spline object with subdivide, tyconform,.. in the stack, so to remove the need max calculate these objects, I do :
- create a snapshot of the object
- deactivate all modifiers
- add editpoly modifier
- remove all geometry in the modifier
- attach snapshot to the geometry.
It works fine for one object.( and I did a script to revert to "normal" geometry )
But when I use this script on multiple selection I got error.
"-- Runtime error: Requested sub-object level out of range: 1"
Anybody could help ? Thanks
	for o in selection where o.modifiers.count > 0 do
		theTMesh = snapshotAsMesh o
		theNewMesh = Editable_mesh()
		theNewMesh.mesh = theTMesh
		convertTo theNewMesh Editable_Poly
		delete theTMesh
		o.modifiers.enabled = off
		cep = edit_poly()
		addModifier o cep
		max modify mode -- !!!
		subobjectLevel = 1
		max select all
		o.modifiers[#Edit_Poly].ButtonOp #DeleteVertex
		o.modifiers[#Edit_Poly].attach theNewMesh
		subobjectLevel = 0
		cep.name = "FREEZED"
selObjsArr = selection as array
for o in selObjsArr where o.modifiers.count > 0 do
Reply to miauu
titane357
Hi, Miauu !
Unfortunately, it make no difference...
Reply to titane357
Panteleev Sergey
you have to select each object inside the loop individually and activate modify panel to make it work
Reply to Panteleev Sergey
titane357
Hi jahman !
I read your post carefully and several times.
But I still don't know what I can do...
Cheers
Reply to titane357
obaida
AND
what you mean BY : "I have spline object with subdivide, tyconform,.. in the stack, so to remove the need max calculate these objects, I do :"
why not just (make a copy , delete all the modifiers and call the object "FREEZED" ?
