Error: unknown property
By Andrey · 2020-04-02
Hello
I worked on the camera parameters interface and ran into a problem.
The interface does not start if the camera is not selected. (Unknown property)
Tell me how to fix this?
Can I see changes in camera settings in my interface?
Comments (10)
You have to edit your code, because when you change values of any of the spinner if the selected object is not your camera you will get an error.
	try(destroyDialog ::Cam_P)catch()
-- 	Cam_P_iso_x = getinisetting "$plugcfg\\CamParam.ini" "Cam_P" "pos_x" as integer
-- 	Cam_P_iso_y = getinisetting "$plugcfg\\CamParam.ini" "Cam_P" "pos_y" as integer
	rollout Cam_P "Cam parameter" width:170
		local camObj = undefined
		local camFilm_Width = 0
		local camFocal_length = 0
		local camFov = 0
		local camZoom_Factor = 0
		group"Options"
			label lf_1 "Film gate" align:#left across:2
			spinner sf_1 fieldwidth:50 range:[0,999,camFilm_Width] type:#float scale:0.01 align:#right
			label lf_2 "Focal length" align:#left across:2
			spinner sf_2 fieldwidth:50 range:[0,999,camFocal_length] type:#float scale:0.01 align:#right
			label lf_3 "FOV" align:#left across:2
			spinner sf_3 range:[0,180,camFov] fieldwidth:50 type:#float scale:0.01 align:#right
			checkbox cf_1 "" width:25 height:25 align:#center offset:[0,-25]
			label lf_4 "Zoom factor" align:#left across:2 offset:[0,-5]
			spinner sf_4 fieldwidth:50 range:[0,999,camZoom_Factor] type:#float scale:0.01 align:#right offset:[0,-5]
		on Cam_P close do
			setinisetting "$plugcfg\\CamParam.ini" "Cam_P" "pos_x" ((GetDialogPos Cam_P).x as string)
			setinisetting "$plugcfg\\CamParam.ini" "Cam_P" "pos_y" ((GetDialogPos Cam_P).y as string)
		on sf_1 changed val do $.film_width = val
		on sf_2 changed val do $.focal_length = val
		on sf_3 changed val do $.fov = val
		on sf_4 changed val do $.zoom_factor = val
		on cf_1 changed true do
			if true then $.specify_fov = on
				$.specify_fov = off
		on Cam_P open do
			if selection.count == 1 do
				if superclassof selection[1] == camera do
					camObj = selection[1]
					camFilm_Width = camObj.film_width_mm
					camFocal_length = camObj.focal_length_mm
					camFov = camObj.fov
					camZoom_Factor = camObj.zoom_factor
					sf_1.value = camFilm_Width
					sf_2.value = camFocal_length
					sf_3.value = camFov
					sf_4.value = camZoom_Factor
	createDialog Cam_P --pos:[Cam_P_iso_x,Cam_P_iso_y]
Reply to miauu
Andrey
Hi Miauu, Thank you so much
Thanks again, the script works.
When the interface starts, I see the camera’s parameters if it is selected. When choosing another camera, I do not see its parameters.
Can I update the interface data when changing the camera?
If yes, please tell me how to do this?
Reply to Andrey
	global miauuSelObjChangedNEC
		local camFov = 0
		group"Options"
		function miauuSelObjChangedNEC_FN s e =
					camFov = camObj.fov
					sf_3.value = camFov
-- 			for a in e wheredo print (getAnimByHandle a)
		on Cam_P close do
				$.specify_fov = off
		on Cam_P open do
			miauuSelObjChangedNEC = nodeEventCallback selectionChanged:miauuSelObjChangedNEC_FN
					camFov = camObj.fov
					sf_3.value = camFov
		on Cam_P close do
			miauuSelObjChangedNEC = undefined
			gc light:true
Reply to miauu
Andrey
Thank you very much
I managed to add data synchronization by your records. Now my interface is fully performing the task. Thanks so much for your answers, they help me study MaxScript.
Please tell me how to reset the interface data when resetting the target?
Reply to Andrey
What do you mean by "resetting the target"? When no camera is selected?
Reply to miauu
Andrey
Yes
Scheme:
1) camera selected - data is updated.
2) no camera is selected (target reset) - the data is updated.
In the second case, if the target is reset, I want to see the data = 0
Just as when running a script without selecting a camera, we see data = 0
For example: I added the name of the camera to the interface - when I reset or select, I can see the changes in the name by analogy with the parameters. If nothing is selected, I will see "nothing"
Reply to Andrey
		local camFov = 0
		group"Options"
		function ResetData =
			camFilm_Width = 0
			camFocal_length = 0
			camFov = 0
			camZoom_Factor = 0
			sf_3.value = camFov
			if selection.count == 1 then
				if superclassof selection[1] == camera then
					camFov = camObj.fov
					sf_3.value = camFov
					ResetData()
				ResetData()
		on Cam_P close do
				$.specify_fov = off
		on Cam_P open do
					camFov = camObj.fov
					sf_3.value = camFov
		on Cam_P close do
			gc light:true
Reply to miauu
Andrey
Thank you
Works great.
When I create a camera, the data is updated.
When I delete the camera, the data is not updated.
I tried to add an interface update when using the delete function - it did not work.
fn (...)=
if selection.count <1 then ResetData ()
if actionMan.executeAction 0 "40020" then ResetData ()
Or should it be written differently?
Thanks.
It helped. I managed to add these events to the function.
Thank you so much for your help.
