ERROR LOOPPING CONTINUOSLY CANNOT CALL FUNCTION JUST ONCE
By artrender · 2013-01-24
I WANT TO REFRESH FORM DEPENDING ON SELECTING OBJECTS(COULD BE SINGLE OBJECTS AS WELL AS GROUPS) THIS SCRIPT http://www.scriptspot.com/forums/3ds-max/general-scripting/how-to-enable… IS GIVING ERROR WHEN WORKING WITH GROUPS, THAT IS WHY I WANT TO USE TIMER
timer clock "testClock" interval:1000 --tick once a second
on clock tick do
fresh_obj_selection=selection as array
if cur_obj_selection!=fresh_obj_selection
then
print("output::"+(fresh_obj_selection as string))
print("output::"+(cur_obj_selection as string))
cur_obj_selection=fresh_obj_selection
Comments (7)
artrender
SOLVED
THANK YOU!
function check_selection = (
this_sel_count = (selection as array).count
updatefunction()
on my_rollout open do check_selection()
artrender
STILL NOT WORKING
THX FOR QUICK ANSWER! MY GOAL IS TO CALL FUNCTION ONLY WHEN I SELECT OTHER OBJECTS
-------------BEFORE ROLLOUT I USE-------------------------
cur_obj_selection = selection as array
------------------AFTER ROLLOUT -----------------------------
--I WANT TO CHECK, IS SELECTION CHANGED OR NOT, IF YES THEN PRINT
--I DON'T KNOW WHY BUT IT'S PRINTING CONTINUOUSLY IF EVEN I DON'T SELECT ANYTHING --ELSE, JUST ONE OBJECT SELECTED
on clock tick do
--fresh_obj_selection=selection as array
fresh_obj_selection = for i in selection where not isGroupHead i collect i
then
--print cur_obj_selection[1]
--print fresh_obj_selection[1]
Reply to artrender
no need UPPER case typing!
You cannot compare arrays directly like a1 != a2.
You should compare all elements stored inside.
And to track SELECTION CHANGED via Timer, hmm...
probably (close enough, but not precise):
on clock tick do
	if selection.count != lastSelCount do
		lastSelCount = selection.count
		print selection
Better is to follow Branko advice and use callbacks.
artrender
TRIED THIS AND IS STILL NOT WORKING
ITS STILL LOOPING, AND IT'S PRINTING EVERY SECOND
"output::#()"
"output::#()"
"output::#()"
"output::#()"
"output::#()"
"output::#()"
"output::#()"
"output::#()"
"output::#()"
"output::#()"
"output::#()"
"output::#()"
on clock tick do
fresh_obj_selection = for i in selection where not isGroupHead o collect o
then
Reply to artrender
Sorry. I correct for-loop. Look the first code (for o in selection ...)
Try to isolate group helper object
fresh_obj_selection = for o in selection where not isGroupHead o collect o
-- or
if isGoupMember selection[1] do ...
