Error "Call needs function or class"
By Bohdan · 2016-10-16
Hello. I am using a script to import animation, but I always get this error "Type error: Call needs function or class, got: undefined". Please help me someone to fix it.
Import Diablo III Animation
Written by Taylor Mouse (c) 04.2014
Added config possibilities
Added Reaper Of Souls Animations
ClearListener()
global startFrame = 10
global d
global configFile = ((GetDir #plugcfg) + "\\d3.config")
STRUCTS
struct D3Bone ( ID, Name, TheBone )
struct TranslationAnimation ( BoneId, KeyFrame, Position )
struct RotationAnimation (BoneId, KeyFrame, Quaternion )
struct ScaleAnimation (BoneId, KeyFrame, Scaling )
HELPER FUNCTIONS
fn ReadBytes stream val =
for i=1 to val do ReadByte stream
fn ReadFixedString stream val =
local str = ""
for i=1 to val do
s= bit.IntAsChar(ReadByte stream)
if(s!="\0") then str+=s
return str
fn SetWorldRotation theNode theRot =
local matrix = transmatrix theNode.transform.pos
in coordsys matrix (theNode.rotation = theRot)
MAIN METHOD
function ReadAniFile file =
d = GetNodeByName "Animations"
if(d==undefined) then d = dummy pos:[0,0,0] Scale:[0.5,0.5,0.5] name:"Animations"
hide d
startingFrame = 0
startingFrame = startFrame
SetUserProp d ((GetFileNameFile file) + " START") (startingFrame as string)
Format " START READING ANIMATION FILE"
stream = fOpen file "rb" -- Open the file for reading
ReadBytes stream 76 -- Skip 76 bytes
animationName = ReadFixedString stream 64 -- Animation name
ReadBytes stream 52 -- Skip 52 bytes
nBones = ReadLong stream -- number of bones
offBones = ReadLong stream -- data for the bones
sizeBones = ReadLong stream -- size in bytes of the bones
ReadBytes stream 12 -- Skip 12 bytes
totalFrames = ReadLong stream -- total frames in this animation
SetUserProp d ((GetFileNameFile file) + " END") ((startingFrame + totalFrames) as string)
offTranslation = ReadLong stream -- data for translation animation
sizeTranslation = ReadLong stream -- size of the translation animation data
offRotation = ReadLong stream -- data for the rotations
sizeRotation = ReadLong stream -- size of the rotation data
ReadBytes stream 8 -- Skip 8 bytes
offScale = ReadLong stream -- data for the scaling
sizeScale = ReadLong stream -- size for the scaling data
ReadBytes stream 208 -- Skip 208 bytes
xan = ReadFixedString stream 256 -- always 0000.xan
source = ReadFixedString stream 256 -- initial location of this file
/* BONES */
fSeek stream ( offBones + 16 ) #seek_set -- jump to the bone data position
allBones = #()
for i=1 to nBones do
b = D3Bone()
b.ID = i --> for reference only
b.Name = ReadFixedString stream 64 -- name of the bone
b.TheBone = GetNodeByName b.Name -- find the bone in the scene
append allBones b
--print allBones
/* Frame data*/
nFrameData = #()
offFrameData = #()
sizeFrameData = #()
/* TRANSLATION */
fSeek stream ( offTranslation + 16 ) #seek_set
for i=1 to nBones do -- get the offset of where the translation data is stored
append nFrameData (ReadLong stream)
append offFrameData (ReadLong stream)
append sizeFrameData (ReadLong stream)
ReadBytes stream 12 -- always 00 00 00 00 - 00 00 00 00 - 00 00 00 00 ?
allTranslations = #()
for i=1 to nBones do -- Read the translation data structure
fSeek stream ( offFrameData[i] + 16 ) #seek_set
for fd=1 to nFrameData[i] do
tran = TranslationAnimation()
tran.BoneId = i
tran.KeyFrame = ReadLong stream
boneY = ReadFloat stream * -17
boneX = ReadFloat stream * 17
boneZ = ReadFloat stream * 17
tran.Position = [boneX,boneY,boneZ]
--tran.Position = [ReadFloat stream, ReadFloat stream, ReadFloat stream]
append allTranslations tran
--print allTranslations
/* Reset Frame data*/
nFrameData = #()
offFrameData = #()
sizeFrameData = #()
/* ROTATION */
fSeek stream ( offRotation + 16 ) #seek_set
allRotations = #()
for i=1 to nBones do -- Read the rotation data structure
rot = RotationAnimation()
rot.BoneId = i
rot.KeyFrame = ReadLong stream
y = (ReadShort stream #signed) / -32767.0
x = (ReadShort stream #signed) / 32767.0
z = (ReadShort stream #signed) / 32767.0
w = (ReadShort stream #signed) / 32767.0
rot.Quaternion = quat x y z w
append allRotations rot
--print allRotations
nFrameData = #()
offFrameData = #()
sizeFrameData = #()
/* SCALE */
fSeek stream ( offScale + 16 ) #seek_set
for i=1 to nBones do -- get the offset of where the scaling data is stored
ReadBytes stream 12
allScaling = #()
for i=1 to nBones do -- Read the scale data structure
s = ScaleAnimation()
s.BoneId = i
s.KeyFrame = ReadLong stream
s.Scaling = ReadFloat stream
append allScaling s
--print allScaling
echo " APPLYING ANIMATION TO THE BONES \n"
-- TODO: get the last used animation key, so we can add multiple animations to the scene
--Apply the Rotation
prevQ = quat 1 -- set a starting rotation
prevB = 1
for i=1 to allRotations.count do
b = allBones[allRotations[i].BoneId].TheBone
if(b == undefined) then continue
t = allRotations[i].KeyFrame + startingFrame
q = allRotations[i].Quaternion
with animate on
at time t (
b.assumeskinpose()
local mtrx = matrix3 1
rotate mtrx (inverse q)
mtrx.row4 = b.pos
if b.parent != undefined then(
mtrx = mtrx * b.parent.transform
b.transform = mtrx
deleteKey b.position.controller (numKeys b.position.controller)
deleteKey b.scale.controller (numKeys b.scale.controller)
-- Apply the Translation
for i=1 to allTranslations.count do
b = allBones[allTranslations[i].BoneId].TheBone
t = allTranslations[i].KeyFrame + startingFrame
pos = allTranslations[i].Position
if(b!=undefined) then
with animate on
at time t
in coordsys parent b.position = pos
-- Apply the Scaling
for i=1 to allScaling.count do
b = allBones[allScaling[i].BoneId].TheBone
scaling = point3 allScaling[i].Scaling allScaling[i].Scaling allScaling[i].Scaling
t = allScaling[i].KeyFrame + startingFrame
if( b!=undefined) then (
with animate on
at time t
in coordsys parent b.Scale = scaling
fClose stream
startFrame += totalFrames + 50
ECHO " DONE"
UTILITY
Utility Diablo3AniImport "Diablo 3 Animation Import"
Group "Animation File"
Button bSelectAniFile "..."
EditText txtSelectedFile
Label lbl01 "Start at frame"
EditText txtFrame text:"10"
Button bGo "Import..." height:35 width:100
On bSelectAniFile PRESSED do
file = getOpenFileName \
caption:"Diablo 3 Animation File" \
types:"Diablo 3 Animation File(*.ani)|*.ani" \
historyCategory:"Diablo3AnimationPresets"
if(file!=undefined ) then txtSelectedFile.Text = file
On bGo PRESSED do
if(txtSelectedFile.text != undefined and (DoesFileExist txtSelectedFile.text == true )) then
startFrame = txtFrame.Text as float
ReadAniFile txtSelectedFile.text
pixamoon
hi, let me know which line of code is generating an error? It's long code to check.
It should be selected by error and written in Listener when error is generated.
