Hi everybody,
I'm facing a problem, in order to build an Edit_Poly triangulation script( without Edit_mesh or Patch conversion) I would like to access to the faces triangulation by script (the diagonals of a face I can see by clicking on "Edit triangulation" on one of the Editable_Poly Modify panel's roll out).
Can somebody learn it to me ?
Thanx by advance.
Sam
Try this
p = convertToPoly(Plane isselected:on)
polyop.setFaceSelection p #{6..7, 10..11}
max modify mode
subobjectlevel = 4
p.toggleCommandMode #EditTriangulation
Thank you for your fast answer. In fact I don't want to toggle the edit mode by code but rather to obtain an array of indexes representing the vertices of diagonals. I continued to try some different solutions, but the only thing that worked is something like :
But I would like not to convert my edit poly to edit_mesh then to convert it back to edit_poly
If you looking diagonal removal tool maybe this can look interesting to you
http://www.scriptspot.com/3ds-max/scripts/quadrifyall
