Edit name
By Mrjacks2o · 2012-01-02
Hi Guys i am having problems with removing parts of the name in maxscript.
For instance i have 2 different edittext,
i want to press a button and it removes the .png from both texts.
thanks in advance
Jos Balcaen
getFilenameFile
you can use :
getFilenameFile "box.png"
(this returns "box")
Reply to Jos Balcaen
Mrjacks2o
Thanks for the reply it worked great for a text i entered in maxscript.
but what if i input a random text lets say box101.png while the script is running how can i use the script to remove the .png? thanks :)
fileName.text = getFilenameFile ".jpg" tried that but it removed all of the text
Reply to Mrjacks2o
Jos Balcaen
varText = edtText.text -- get input from user
fileName.text = getFilenameFile varText -- remove extention from input
getFilenameFile ".jpg" will return an emty string because getFilenameFile will remove the extention and ".jpg" is only an extention.
check maxscript help for more info. search for getFilenameFile.
