Hi
No used to using Script Spot and a bit over my head. But I have an important work question that hopefully I can find an answer too. Here goes.
I have a robot rigged using an Attribute holder and wire parameters. Each robot are has 6 degrees of movement with a roll control for each in the Attribute list. Is it possible to drive these joint from outside of 3DS Max by an external database. I would like to have the degrees of movement to be able to go either way so if I move the Max model the joint information would go out to a database and if I changed the database out side of Max the model would move. Hope this makes sense? :)
Really looking forward to finding an answer to this question. If you need more info please ask.
Regards
Rog :)
