Draw spline to closest points
By Joel Brehm · 2012-02-28
Hello, I am fairly new to scripting in 3ds max, but have been impressed with it's capabilities so far.
I have a project where I have received a file with a list of xyz coordinates and I would like to draw a spline between each point and a spline to each of the points around it.
I have written a script that reads in all of the points and connects them with one line, which isn't exactly what I'm looking for. (goldcage2.jpg)
When I open the original xyz file with a program called ViewerLite, it correctly connects all of the vertexes, like this:
(goldcage.jpg)
Here is my script so far:
theFilename = getOpenFileName types:"Comma Separated Values (*.CSV)|*.CSV|All Files (*.*)|*.*"
if theFilename != undefined do ( --if a valid filename picked
local theFile = openFile theFilename --open the file
s = splineshape()
idx = addNewSpline s
while not eof theFile do (
addKnot s idx #corner #line (Point3 (readValue theFile) (readValue theFile) (readValue theFile))
updateShape s
Is there an easy way to connect all of the closest vertexes with a spline, sort of like ViewLite does? Am I even on the right track?
kilad
one hacky hit & miss
one hacky hit & miss approach:
First collect all point3s to an array.
Then for each point p collect the points that are within a threshold distance from p.
Draw a single spline from p to all these points.
Ofcourse you would get multiple splines at the same place..
To get around this you could create a struct that holds vector and lenght for each spline:
lines=#()
struct line (vector, length, on create do (append lines this))
fn drawLine p1 p2=
s = splineshape()
addnewspline s
addKnot s 1 #corner #line p1
addKnot s 1 #corner #line p2
updateshape s
Then in your loop you could check if there exist a line in lines that have the same vector and length that you are about to create. If not create it and a new line struct.
distanceThreshold=10 --or whatever the scale of your scene
for pos in point3Array do
closePositions = for i in point3Array where (distance pos i)> 0 and (distance pos i)< distanceThreshold collect i
for cPos in closePositions do
vector = normalize(pos-cPos)
sLength = distance pos cPos
doesExist = false
for line in lines do --maybe check to see if lines.count>0 first
if (line.vector == vector and line.length == sLength) do (doesExist = true; continue)
if doesExist == false do
drawLine pos cPos
line vector sLength
something like that...haven't tested it, so you might get some errors..
Reply to kilad
Joel Brehm
That's pretty much exactly what I was looking for. Made a couple minor tweaks, but it does the trick.
Thanks!
lines=#()
s = splineshape()
addnewspline s
fn drawLine p1 p2=
updateshape s
--Then in your loop you could check if there exist a line in lines that have the same vector and length that you are about to create. If not create it and a new line struct.
distanceThreshold=4 --or whatever the scale of your scene
doesExist = false
for line1 in lines do --maybe check to see if lines.count>0 first
if (line1[1] == vector and line1[2] == sLength) do (doesExist = true; continue)
drawLine pos cPos
newLine=#(vector,sLength)
append lines newLine
Reply to Joel Brehm
Ben Robinson
Any chance you could detail full code
Any chance you could detail the full code..is there a version that works on 2013. Thank you.
