dotNetControl TextBox lost text formating when change enabled state.
By Romain Hua · 2013-08-12
hello,
I actually trying tu use the dotnet Textbox, But i encounter a problem, when i change his enabled state, the TextBox lost text formating, As you can see in the short code bellow.
Do you know an alternative that can keep formatting when textbox is disable? (or may be i made a mistake..)
rollout rolTest "Test"
dotNetControl custtxt "System.Windows.Forms.TextBox" pos:[16,25] width:240 height:144
checkbox actcc "active/desactive" pos:[17,200] width:232 height:16 checked:false
on rolTest open do (
custtxt.Multiline = true;
custtxt.ScrollBars = custtxt.ScrollBars.vertical;
custtxt.text = "blzaezijfnai afarfijnazf \r\n DFZAFEAZFd"
on actcc changed theState do (
if actcc.checked == true then ( custtxt.enabled = false )
else ( custtxt.enabled = true )
createDialog rolTest 400 400
Yep. This is the thing with .net. Instead of "Enable" propertie you can use "ReadOnly" if you want to preserve formatting.
BTW is not only the problem with textbox, also others ctrls where you can edit text or some values have same problem.
