Does macroscript support toolTip:"...." with line break?
By Haider Alghifary · 2014-03-14
Hi!
In a Macroscript, is it possible to put a long description with line breaks?
Comments (16)
Haider Alghifary
@barigazy: Maybe this is not good idea. I don't want to confuse Haider :)
Keep on confusing me, this is just awesome ;)
@miauu
thanks for the demo. Too bad it is not working
The reason why I needed to know more about this is to see how much more additional information I could add into a toolbar, for example information about the author, script version and such.
In Maya, there was a trick that allowed you to show stuff if you had alt or ctrl-button pressed and hover the mouse pointer over the button.
Reply to Haider Alghifary
For standard MXS controls like buttons etc. you can have same behavior by using (Shift, Alt, Ctrl, LMB, RMB). This does not apply to macro buttons ei. toolbar buttons but only controls inside Rollout Dialog.
In the other hand .NET allows you to expand this functionality of control even more by using events:
- MouseDown
- MouseUp
- Click
- MouseHover
- MouseLeave
- etc.
Also property of arguments "Buttons" can be "Left", "Middle", "Right" like LMB, MMB, RMB.
In this way you can make custom controls. I mean instead of using button U can achive same behavior usin simple Label control. Also checkbox can be easely transformed to checkbutton or radiobuttons to checkboxes or textbox to spinner etc.
Regarding to this Max have more "magical" stuffs then Maya for sure
Reply to Branko Živković
That is also another reason why I do not use macros.
Do not waste time on this. I suggest you to explore MXS practicle examples rather than this. I mean how to correctly write and optimize code.
There is the fun and excitement of course.
Haider Alghifary
@barigazy
Sometimes, I ask things out of curiosity, maybe for future ideas. Depending on if things are possible or not, I elaborate my thoughts into larger ideas, or skip them.
Btw, why dont you like Macros? As an amateur, I cant but help thinking "isnt it just the same?". An MCR file contains script encapsulated in a macroscript header. Or what am I missing?
@miauu
Can you elaborate this a little more, with some examples? Thanks
I don't blame you because I'm curious most of the time even when I sleep :)
I write scripts for other people but mainly to speed up my current workflow.
Most of these tools are intended for one time job but not for next project.
It's easier for me to organize these tools in specific folders and manually run these (or with ScriptRun tool) then cleaning all the time old macros from toolbars, quads, menus. Worst case scenario is reassigning keyboard shortcuts over and over again. And that's nightmare for me. :)
Anyway I do not dispute their use but I like to use different way. :)
Rollout control with multi lines tooltip:
	global rol_TooltipTest
	try(destroyDialog rol_TooltipTest)catch()
	rollout rol_TooltipTest ""
		button btn_01 "--------" tooltip:"First line\nSecond Line\nand so on..."
	createdialog rol_TooltipTest
In this case the UI control is a button, but how the tooltip is set is valid method for all controls that can have tooltips.
Reply to miauu
Do you want to see tooltip with different words size and different words color also? ;)
Ok. Just small "sneek pick"
With dotNEt almost everything is possible. Maybe there is a way to do what you say with the default maxscript tooltips using some switches.
But I found how to ruin your 3ds max. What you have to do is to:
- install a macro script
- create a toolbar button and assign the macro to the button
- close 3dsMax.
If in your Preferences the Save UI COnfiguration on Exit is turned On next time when you wants to run the Max you will be surprised that this is not possible. My max2014 loads only 226-228MB of RAM and then the result is Not Responding. :)
Reply to miauu
Nice try. Very cool :)
This is not .NET but DevXpress :)
DexX controls have propery "SuperTip".
Even with this property you need to design your tooltip.
But you can use Paint event with .NET control to achive the same.
Also not so easy :)
You can have multi lines tooltips for the rollout buttons, but for macroscripts - you can't. Aslo there are some special characters that if be used in the tooltip description will not allows you to load the macroscript.
Haider Alghifary
Unfortunately, I didn't find, why I ask here.
Besides, asking here feels more social :)
Ok. You can ask here what ever you want but I not like macros and not have answer for your question. Your last 3-4 posts are about macros. So... ;)
fajar
instead of asking , why dont you read maxscript help first. you'll find your answer sooner.
