Maybe somebody know a simple way to remove variables what was created during the script testing for example if you create rollout
rollout rl_test "Some Rollout" width:100 height:100
checkbutton myButton "My Button" width:80 height:24
createDialog rl_test
if I execute code bellow before rollout is created
rl_test.myButton.state
then I get
-- Unknown property: "myButton" in undefined
and this is fine because max doesn't know about such a rollout and button
but after rollout was created it always returns some value even if rollout was closed. Maybe are some smart way to clear this data from Max memory without restarting Max.
var = undefined
the simplest way is just to set your variable to undefined --
that not remove those variable from the global space memory, but its quite enough for testing, and to remove them completely you can use
structore --
But read the notes about globalVars in the help, Cheers!
