disable item in RC menu and in dropdownList menu
By artrender · 2013-05-05
I have a RCmenu and It's working fine, but I don't know how to disable item in some circumstances
fn createMenu =
	rcMenu rcTest
		menuItem miItem1 "name1"
		menuItem miItem2 "name2"
		menuItem miItem3 "name3"
		seperator menuSep01
		menuItem miItem4 "name4"
        if a==0 then
           miItem1.enabled = false  --<<<<<< ??????????????????? >>>>>
        on miItem1 picked do
	   print "1"
and a dropdownList menu where I want to disable items:
 dropdownList FilterSelect pos:[427,21] width:110 height:200
items:#("001", "002", "003", "004")
if a == 0 then item "002".enabled = false
Comments (16)
artrender
srry
it's my fault! I wanted to call delete item in another function but inside yours it's working!!
artrender
i've tried
deleteItem BitmapLister.FilterSelect.items[9]
and
deleteItem BitmapLister.FilterSelect.items(finditem BitmapLister.FilterSelect.items "Map Intances")
and first gives error, the second does not delete!
Reply to artrender
when you use deleteItem method then you need:
deleteItem array index
artrender
Barigazy
I get error for deleteitem
>> MAXScript Rollout Handler Exception:
-- No "deleteItem" function for "Map Intances" <<
artrender
this is what I've came up with
try(form.close()) catch()
	global form = dotnetobject "MaxCustomControls.Maxform"
	form.ShowInTaskbar = form.MinimizeBox = form.MaximizeBox = off
	form.StartPosition = form.StartPosition.Manual
	form.Bounds = dotnetobject "System.Drawing.Rectangle" 800 200 100 60
	cm = dotNetObject "ContextMenu"
	fn onPopup s e =
		--fn onClick s e = undo "Delete" on deletemodifier s.parent.tag.value s.tag.value
		fn onClick s e = print "haha"
		for n in selection do
			item = dotnetobject "MenuItem" n.name
			item.tag = dotnetmxsvalue n
			item.enabled = true--(n.modifiers.count > 0)
			s.menuitems.add item
			dotnet.addEventHandler item "Click" onClick
	fn onCollapse s e = s.menuitems.Clear()
	dotnet.addEventHandler cm "Popup" onPopup
	dotnet.addEventHandler cm "Collapse" onCollapse
	form.ContextMenu = cm
	form.showmodeless()
	delete objects
	for k=1 to 8 do
		n = #(box, sphere, cylinder, cone)[random 1 4] pos:(random -[50,50,50] [50,50,50]) wirecolor:(random red green)
		for i=1 to (random 0 5) do addmodifier n (#(UVWmap, Unwrap_UVW, Edit_Poly, Edit_Normals, XForm)[random 1 5]())
	redrawviews()
But how to use this menu in maxscript with rollout? How to add separator, how to detect which item was picked like in standard rcmenu?
artrender
Oh, yeeeeeeeeeeeeeees!!!
this is a HUGE HELP, BARIGAZY!
THANK YOUUUUUUUUUUU!
artrender
Barigazyyyyyyyyyyyyy! Thank you soooo much!
Help me please to disable items in RCMenu or to add them at a certain level (for example between item 2 and 3)
Reply to artrender
I told you I not use RCMenu
Better way
fn defDDListItems ddlist choise: itm: =
ddlist.items = case choise of
(0): deleteItem ddlist.items (finditem ddlist.items itm)
(1): deleteItem ddlist.items (finditem ddlist.items itm)
(2):
local arr = ddlist.items
appendIfUnique arr itm ; sort arr
default:#("001", "002", "003", "004") -- if not used 0,1,2 or any other choise
dropdownList FilterSelect pos:[427,21] width:110 height:200 items:#("001", "002", "003", "004")
defDDListItems testroll.FilterSelect choise:0 itm:"002"
defDDListItems testroll.FilterSelect choise:1 itm:"004"
defDDListItems testroll.FilterSelect choise:2 itm:"006"
defDDListItems testroll.FilterSelect choise:#default itm:
Reply to Branko Živković
This is very cool and much better then RCmenue
#1 examples by DenisT
global form
form.ShowIcon = form.ShowInTaskbar = form.MaximizeBox = form.MinimizeBox = off
form.Text = "Owner Draw Menu Item"
form.Bounds = dotnetobject "System.Drawing.Rectangle" 500 300 200 100
fn onDrawItem s e =
g = e.Graphics
g.PixelOffsetMode = g.PixelOffsetMode.HighQuality
g.SmoothingMode = g.SmoothingMode.HighQuality
case of
(dotnet.compareEnums e.State e.State.Selected):
back = (dotnetclass "System.Drawing.Brushes").LightSalmon
fore = (dotnetclass "System.Drawing.Brushes").Black
default:
back = (dotnetclass "System.Drawing.Brushes").Salmon
g.FillRectangle back e.Bounds
g.DrawString s.Text (dotnetobject "System.Drawing.Font" e.Font e.Font.Style.Bold) fore 16 10
fn onMeasureItem s e =
e.ItemHeight = 40
e.ItemWidth = 100
item = cm.menuitems.Add "Geometry"
item.OwnerDraw = on
item.Enabled = off
dotnet.addeventhandler item "DrawItem" onDrawItem
dotnet.addeventhandler item "MeasureItem" onMeasureItem
fn onItemClick s e = (format "click: %\n" s.Text)
item = cm.menuitems.Add "Sphere"
dotnet.addeventhandler item "Click" onItemClick
item = cm.menuitems.Add "Cone"
form.Showmodeless()
#2 examples by DenisT
enjoy!
fn onPopup s e =
item.enabled = (n.modifiers.count > 0)
for m in n.modifiers do
i = dotnetobject "MenuItem" m.name
i.tag = dotnetmxsvalue m
dotnet.addEventHandler i "Click" onClick
item.menuitems.add i
form.showmodeless()
delete objects
for k=1 to 8 do
redrawviews()
Reply to artrender
In second example you can see how to disable items.
Select some yellow object and press rightclick on form
artrender
BUT
Is it possible to add items?
Reply to artrender
I not like RCMenu but it's posible to disable a item. Never mind, let's continue with dd list
testroll.FilterSelect.items = case a of
(0): deleteItem testroll.FilterSelect.items (finditem testroll.FilterSelect.items "002")
(1): deleteItem testroll.FilterSelect.items (finditem testroll.FilterSelect.items "004")
(2):
local arr = testroll.FilterSelect.items
appendIfUnique arr "005" ; sort arr
artrender
ok!
I will try now!
artrender
Thx Barigazy! Again YOUUUUUUUUU save me!
do you mean to remove items? Will this work for rcmenu also?
You can't disabled item in dropdown list. But you can do this
--load on creation
itmArr = case a of
(0): #("001", "003", "004")
(1): #("001", "002", "003")
FilterSelect.items = itmArr
-- or remove affter creation
--Let's say your rollout name is testroll
