What is wrong in this script?
macroScript DIMline category:"DIMaster" icon:#("DIMaster",1) tooltip:"Create a DIMline measuring the distance between two points..."
global DIMaster_p1 = undefined
global DIMaster_p2 = undefined
global DIMaster_p3 = undefined
global DIMaster_theDim = undefined
global DIMaster_firstPoint = undefined
global DIMaster_theText = undefined
result = startTool createDimensionLine
if result == #abort do
try(delete DIMaster_theText)catch()
try(delete DIMaster_p1)catch()
try(delete DIMaster_p2)catch()
try(delete DIMaster_theDim)catch()
macroScript DIMangle category:"DIMaster" icon:#("DIMaster",2) tooltip:"Create a DIMangle measuring the angle between three points..."
result = startTool createDimensionAngle
try(delete DIMaster_p3)catch()
macroScript DIMnote category:"DIMaster" icon:#("DIMaster",3) tooltip:"Create a DIMnote displaying position, distance, speed, custom object properties or user-defined text..."
result = startTool createDimensionNote
macroScript DIMlineMulti category:"DIMaster" icon:#("DIMaster",4) tooltip:"Create multiple DIMline objects measuring distances between pairs of points..."
local isCheckedVar = false
on isChecked return isCheckedVar
on execute do
isCheckedVar = true
local result = #go
while result != #abort do
macroScript DIMangleMulti category:"DIMaster" icon:#("DIMaster",5) tooltip:"Create multiple DIMangle objects measuring angles between sets of three points..."
on execute do
isCheckedVar = true
local result = #go
macroScript DIMnoteMulti category:"DIMaster" icon:#("DIMaster",6) tooltip:"Create multiple DIMnote objects displaying positions, distances, speeds, custom object properties or user-defined texts..."
on execute do
isCheckedVar = true
result = #go
macroScript DIMasterDelete category:"DIMaster" icon:#("DIMaster",7) tooltip:"Delete DIMaster objects whose elements (Points, Lines or Texts) are currently selected..."
with undo "DIMaster Delete" on
theSel = selection as array
for o in theSel where isValidNode o do
DIMasterFunctions.DeleteCallback o
macroScript DIMasterAttach category:"DIMaster" icon:#("DIMaster",8) tooltip:"Toggle Attaching the DIMaster object's Control Points to Snapped Points on Geometry Objects. Requires 3D Snaps."
global DIMaster_AttachToSnapped
on isChecked return DIMaster_AttachToSnapped == true
on execute do
if DIMaster_AttachToSnapped == undefined do DIMaster_AttachToSnapped = false
DIMaster_AttachToSnapped = not DIMaster_AttachToSnapped
Do you have the DIMaster installed properly?
You need to declare Mouse Tools for:
createDimensionLine
createDimensionNote
Take a look on maxscript help:
http://help.autodesk.com/view/3DSMAX/2016/ENU/?guid=__files_GUID_80E8ADD…
Best,
Pixamoon
