Detecting Max object types
By Mike Wilson · 2013-03-13
I think a really simple question. Writing a script that manipulates Max text objects - including changing the text. For error checking i need to be able to tell if the selected object is a text object. If it's a mesh object like Sphere001, or Plane001, the script will die as
$.text
is undefined for those object types.
I'm looking for a conditional test that i can wrap around all my text control commands.
if ($ is a text object) then
do all the text stuff
warn user to select text object
Thanks!
to continue
other conditional tests:
if getclassname selection[1] == "Text" do...
You can also use unique text shape properties for checking like
obj = selection[1] -- define variable selection
if isProperty obj "kerning" do...
--or
if isProperty obj "leading" do...
--etc.
to collect all text "stuffs" ;)
if selection.count != 0 do
	if iskindof (txt=selection[1]) text then
		clearlistener()
		local props = getpropnames txt
		for i = 1 to props.count do format ("$"+txt.name+"."+props[i] as string + " = %\n") (getProperty txt props[i])
	else messageBox "You need to pick text shape first!" title:"Warning" beep:off
Then open the listener to see the result
if classof $ == text then
if classof $ == text then ...
if isKindOF $ text then ...
or you can use
	if classof $.baseobject == text then ...
	if isKindOF $.baseobject text then ..
Reply to miauu
Mike Wilson
Thanks!
This forum is really a huge help to newbies. The Max Script docs are complete but there's so much detail. It's hard to know what to search for.
Thanks again - to both responders!
