detect unicode file names and rename them!
By artrender · 2013-04-02
How to DETECT non-english characters inside file names and rename them???
Please help!
Comments (12)
jazznazz
Fixed Function that is essentially a whitelist for a string - it srtips all characters that are not present in the latinChars string:
	latinChars = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789"
	function OnlyLatinChars str =
		local strCnt = str.count
		if strCnt != 0 do
			for i = strCnt to 1 by -1 where (findString latinChars str[i] == undefined) do
				str = replace str i 1 ""
		str
	newStr = OnlyLatinChars "ヒグループホールデФЦЦШЩЧЧ.Qwerty32___"
the output is "Qwerty32"
Reply to jazznazz
Two more versions ;)
-- VER#1
	fn OnlyLatinChars str = if isKindOf str string and str.count != 0 do
		string = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789" ; value = ""
		for i = 1 to str.count where (findString string str[i] != undefined) do append value str[i]
		value
-- VER#2
	fn OnlyLatinChars str letters:"ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789" =
			value = ""
			for i = 1 to str.count where (findString letters str[i] != undefined) do append value str[i]
			value
Tasha Hill
Unicodes file creates a complex error during the running program and stocking everything and also creating a really big bug. So that many helpful medium https://www.topdissertations.org/edubirdie-review/ help the developer for this purpose.
amir3dsmax
can any one give me the code . i need this
Glad you found the solution.
artrender
THX! SOLVED
Thank you so much
artrender
this idea is great!
what is theChars?
Except this I want first to detect if a filename contains at least a non-latin character and to display it
if m.filename conatins non-latin
then print m.filename
It is because: If I have a texture with nonlatin name (nonlatin.jpg) then after deleting nonlatin characters you could achive a file .jpg without name
or after renaming 2 textures:
"nonlatin1"001.jpg and "nonlatin2"001.jpg you could get 2 textures with the same name!
In order to detect first if the file contains nonlatin characters there is no need to control the name till the end and
it means inside "for" I should break the cicle:
	local latinChars = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789 "
	function foreignfn fname =
		local counter=0
		for i = fname.count to 1 by -1 where (findString latinChars fname[i] == undefined) do
			if (counter=counter+1)==1 then
				False
				True
	for m in getClassInstances BitmapTexture where (foreignfn m.filename == true) do
 		print m.filename
Could YOU help me to make corrections in this script PLEASE?!!!
Try this
	local latinChars = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789"
		if strCnt != 0 do
			for i = strCnt to 1 by -1 where (findString theChars str[i] == undefined) do
		str
	newStr = OnlyLatinChars latinChars
You can add it in the function above.
artrender
thx
but what if a filename has russian characters or chinese, or greek or any other? They can contain not exactly characters from this list! They could contain others as well!
Should I give allowed latin alphabet with numbers or there is other way as well?
Try this function:
-- function to make a filename valid by replacing illegal characters with a '_'
		function MakeFileNameValid fileName = -- fname must be just filename, no path....
			local illegal_characters =":/\\~!@#$%^&*()+=|'?><;[]{}\"" -- illegal characters in file name
			local res = copy fileName
			-- make sure the object name is legal for a filename
			local count = res.count
			for i = 1 to count do
				if (findString illegal_characters res[i]) != undefined do -- replace illegal characters with _
					res[i] = "_"
			res
artrender
I've found smth like this for php and javascript
php
if (preg_match('/[^\x30-\x7F]/', $_POST['full_name']) > 0)
    $error = true;
x30 will exclude: !"#$%&'()*+,-./.
java
var foreignCharacters = $("#foreign_characters").val();
var rforeign = /[^\u0000-\u007f]/;
if (rforeign.test(foreignCharacters)) {
  alert("This is non-Latin Characters");
} else {
  alert("This is Latin Characters");
how to implement these things in maxscript:
rename m.filename
For the other hand we have:
character.set parameter for maxscript! I'm still confused!!!
