DESELECT row in datagridview by defolt
By artrender · 2013-02-25
table.rows.clear()
table.ClearSelection
table.CurrentCell = Nothing
--doesn't help
table.CurrentRow.Selection = False
--gives error
Comments (8)
artrender
THANKS A LOT
this code worked for me:
table.rows.item[0].cells.item[0].Selected = False
artrender
STILL ERROR
Even with counter = 0
Reply to artrender
change all (counter) to [counter]
Yep, I think we miss the syntax conversion :)
In DotNet languages call to item by index is surrounded with round brackets "()", for example:
table.Rows(counter).Index
, while in MaxScript with square brackets "[]", like:
table.Rows[counter].Index
So, fix that too (in all places), and lets hope there no more chunks.
artrender
I didn't use uny value
I have just used your code! I don't what value should I use for counter!
Reply to artrender
integer
the "counter" in the example code serve as variable, it s'd be integer value, for example 0.
counter = 0
artrender
Thx Anubis!
		table.SelectionMode = (dotNetClass "System.Windows.Forms.DataGridViewSelectionMode").FullRowSelect
		table.RowHeadersVisible = false
		table.FirstDisplayedScrollingRowIndex = table.Rows(counter).Index
		table.Refresh() -- refresh after scroll
		table.CurrentCell = table.Rows(counter).Cells(1)
		table.Rows(counter).Selected = True -- use #Selected with Boolean
I get error
Type error: Call needs function or class, got:
dotNetObject:System.Windows.Forms.DataGridViewRowCollection
table.CurrentRow.Selected = False
gives -- Unknown property: "selected" in undefined
Reply to artrender
probably something missed
what you used for "counter" value?
counter = ?.. --some integer
I not use DataGridView so take my words as friendly attempt to help. What I did is just quick search.
I'm not sure if there exist #Selection property for CurrentRow, but found that CurrentCell cannnot be set to Nothing. You s'd set that property to valid Cell which s'd be visible as well, i.e. need to scroll if necessary. Shortly, something like this:
--counter = ...
--DVG.ClearSelection()
DGV.FirstDisplayedScrollingRowIndex = DGV.Rows(counter).Index
DGV.Refresh() -- refresh after scroll
DGV.CurrentCell = DGV.Rows(counter).Cells(1)
DGV.Rows(counter).Selected = True -- use #Selected with Boolean
I hope this help
