Delete folder
By Aline3D · 2007-02-28
Hi friends,
I have some problem, i need delete folder but not have code in maxscript for this.
 PS: they had understood? my english is very very bad😳
3dwannab
HiddenDOSCommand
Lets not forget the HiddenDOSCommand which runs in the background. No annoying flash on your screen.
slimatron
folder deletion
Even neater, try the dotnet method:
fileClass = dotNetClass "System.IO.Directory"
fileClass.Delete @"c:\directoryName" true
true sets the deletion to recursive so you delete all the files and subfolders
simples...
Reply to slimatron
ei.
fn deleteFolder folderPath: =
local sioDir = dotNetClass "System.IO.Directory"
if (SIODir.Exists folderPath) do SIODir.Delete (folderPath) true
--example
deleteFolder folderPath:"c:\\temp\\TestFolder"
arketip
You could try the DOSCommand()
Something like this:
DOSCommand "rd c:\\theFolder"
Don't forget to use a double \\ in the path name because the command is a filename string
