Delete an instance of a Structure (destructor)
By Rodman · 2013-12-09
The documentation doesn't mention how an instance of a structure is managed once it's created. Is there a destructor like in C++ ? In other words, can we release the memory used by this instance ?
I would say yes if you affect the value undefined to the instance but I'm not sure.
Also, if you create an instance twice (same name of the instance), the memory of the fisrt instance will be released or not ?
I think using "undefined" is the answer for all your questions
Ok, so the code below is correct ?
Struct theStruct
 -- some stuffs here, allocating memory
instance = theStruct()
instance = undefined -- clear the memory
Reply to Rodman
Yup. But don't use word "instance" as variable
