defining an array as a custom attribute
By michael · 2012-09-10
Ok, at the moment, I am trying to make an array as a custom attribute.. Only problem, I'm getting the following weird error:
-- Error occurred in anonymous codeblock; filename: J:\Dropbox\ICT312 (1)\scripts\entityAttribs.ms; position: 579; line: 30
-- Unable to convert: #() to type: String
for the following code:
newAttrib = attributes entityAttrib
	parameters posParam rollout:entParams
		isStatic type:#boolean ui:isStatic checked:false
		castShadow type:#boolean ui:castShadow checked:false
		isChild type:#boolean
		childeren type:#()
	rollout entParams "Entity Atributes"
		checkbox isStatic "Static Entity"
		checkbox castShadow "Casts Shadows"
		edittext isChildTxt "is child" text:"no"
		on isChild changed do
			if isChild == true then
				isChildTxt.text = "yes"
				isChildTxt.text = "no"
custAttributes.add $ newAttrib
--and then use >>
$.baseObject.entityAttrib.castShadow = on
$.baseObject.entityAttrib.isStatic = on
$.baseObject.entityAttrib.isChild = on
$.baseObject.entityAttrib.childeren = on
isProperty $.baseObject #castShadow
isProperty $.baseObject #isStatic
isProperty $.baseObject #isChild
isProperty $.baseObject #childeren
if I follow tutorials on how to make an array inside of just any odd script, not inside of a custom paramater, i.e.
childeren = #()
I get the following error:
-- Error occurred in anonymous codeblock; filename: J:\Dropbox\ICT312 (1)\scripts\entityAttribs.ms; position: 231; line: 8
-- Syntax error: at =, expected name
--  In line: 		childeren = #
I know it's probably something silly.. But I can't for the life of me understand why my array isn't working inside of a parameters :(
Is there a proper way??
If anyone's curious, the reason why I need an array is because I'm holding children meshes inside of an array (needed for proper extraction of scene data for exporter)
Comments (14)
How in gods earth do you find these things.. I search for hours...
I'll check out in full in the morning.. 3am isn't best time to script
Reply to michael
The basic rule:
only that you need is to know what do you want and place where to find.:)
Hope this help.
Cheers man!
At the end of code you probable noticed the line "max modify mode".
This is important because by switchin command panel to modfy mode
you create CA rollout and thus avoiding errors
I hate to ask stupid questions, but you can probably tell, that I aint really all that familiar with MaxScript.. Is there anyway I can intigrate an array into this function
		childeren type:#nodeTab
		edittext isChildTxt "is child" text:"no" readOnly:true
		button selectChilderen "add child" across:1
		--on selectChilderen pressed do
			--deselect $
			--if
--and then use >>
$.baseObject.entityAttrib.isChild = false
I' just really not confident with the language as a whole and I understand how that code words and I feer translating my code into that other structure will cause more and more stupid little problems Ide know how to fix if I knew the language better. And I would learn the language better, but by the looks of it it's an experience language, meaning u learn from eperience.. Unfortunately I don't have 4 weeks to learn.
It sounds like I am being lazy here and just not doing the hard hours.. But trust me, I am doing the hard hours.. I am in final year uni with 2 other units all demanding all my time.
Reply to michael
If I understand you correctly you want when press button "add child"
to collect all children nodes of current selection and store it in
"children" array.Right?
yes correct, then my exporter would make it a node inside of itself, here's an example of our XML structure.
<root>
  <static>
    <name> Box001 </name>
    <position>
		<x> -6.34422 </x>
		<y> 0.0 </y>
		<z> -0.827736 </z>
	</position>
	<rotation>
		<x> 0.0 </x>
		<y> 0.0 </y>
		<z> 0.0 </z>
	</rotation>
	<scale>
		<x> 1.0 </x>
		<y> 1.0 </y>
		<z> 1.0 </z>
	</scale>
    <castShadow> true </castShadow>
      <static>
        <name> Box002 </name>
        <position>
			<x> -6.34422 </x>
			<y> 0.0 </y>
			<z> -0.827736 </z>
		</position>
		<rotation>
			<x> 0.0 </x>
			<y> 0.0 </y>
			<z> 0.0 </z>
		</rotation>
		<scale>
			<x> 1.0 </x>
			<y> 1.0 </y>
			<z> 1.0 </z>
		</scale>
      </static>
  </static>
</root>
box02 in this case is a child of box01
don't worry about my ability to export the XML, it's already up and running, all I'm doing now is adding all the attributes for it to export
Reply to michael
Here we go
now you can collect all children nodes of current selection and store it in children array.
Press the button and look what Listener throw
childeren type:#nodeTab tabSize:0 tabSizeVariable:on
local thisObj = (refs.dependents (custAttributes.getOwner this))[1]
this.childeren = for c in 1 to thisObj.children.count collect thisObj.children[c]
format "chi = %\n" this.childeren
would you be able to break down this:
I think I understand it, the first line finds the item which this rollout is attached to, the next one itterates through all the elements inside of the childeren array...
one problem...
my code doesn't seem to be working :( again :(
global currBody
fn waitOnSelect =
	while $ == undefined do
		--waiting for user to select object
	if $ != currBody then
		--currBody.baseObject.entityAttrib.childeren[currBody.baseObject.entityAttrib.childeren.count + 1] = $
		append currBody.baseObject.entityAttrib.childeren $
		format (currBody.baseObject.entityAttrib.childeren[1].name as string)
		format  "you can't add yourself to your childerens list\n"
rollout main "tester"
	label testOutput "test output:"
	editText outputdata height:100
	button testBut "test code" across:1
	on testBut pressed do
		currBody = $
		deselect $
		MainThread = dotnetobject "CSharpUtilities.SynchronizingBackgroundWorker"
		dotNet.addEventHandler MainThread "DoWork" waitOnSelect
		MainThread.RunWorkerAsync()
MoCapFloater = newRolloutFloater "Test executer" 500 188 100 100
addRollout Main MoCapFloater
neither
or
add it to the childerens array :( any help?
Sorry for heaps of questions.. just this is kinda vital and I have no where near enought max experience
Reply to michael
Aha, i see that. You're an inexperienced user who know all about Beckground Worker, XML and when construct. tell me about it :)
I know somethig about BGWorker and XML but i never use before when construct.
You need to explaine what do you want to achive now?
If you need to append picked object in "children array" try to use pickbutton.Then you don't need other advanced fn
Maybe this is not best solution
hlp = Dummy()
local childerens = #("content1","content2","content3")
if isChild == true then (isChildTxt.text = "yes")
else (isChildTxt.text = "no")
custAttributes.add hlp newAttrib
format "childrensArr = %\n" (hlp.baseObject.entityAttrib.childrens)
Ill try that in a second, but I think I found a solution anyway:
		childeren type:#maxObjectTab
Right now my issue is that I need to get my script to deselect the current object, and then add the next selected item to the childerens list.. so far this is my script:
currentBody = $
deselect $
--if $ == undefined then
if $ != currentBody then
append $.baseObject.entityAttrib.childeren $
outputdata.text = "body: %, added to childeren of %" $.name currentBody.name
outputdata.text = "you can't add yourself to your childerens list"
I thought scripts ran as a subroutine, aparently not.. as soon as it reaches the while loop 3ds max freezes =.= is there a better/proper way to get the user to select another object?
Reply to michael
michael
Who'da known, you can multitask in ms after all, ok, so that's all handled, now I would love to know, how can I make a dynamicly sized maxObjectTab
-- Error occurred in waitOnSelect(); filename: J:\Dropbox\ICT312 (1)\scripts\test2.ms; position: 250; line: 13
--  Frame:
--   outputdata: undefined
>> MAXScript dotNet event handler Exception:
-- Runtime error: Array parameter size fixed, cannot dynamically expand: childeren <<
the definition of the datatype is this:
and the error is caused by:
Is there any dynamic types so I can add to somthing simular to maxObjectTab?
Reply to michael
This is en excellent example by DenisT
This is the way how to solve the array problem
global nodeTabAttr = attributes nodeTabAttr attribID:#(0x1cabedab, 0x5551de47)
parameters main rollout:main
nodes type:#nodeTab tabSize:0 tabSizeVariable:on
on nodes tabChanged do
this.main.nodes_count.text = (nodes.count as string)
rollout main "Nodes"
edittext nodes_count "Nodes Count: " text:"0" fieldwidth:40 readonly:on
on main open do nodes_count.text = (this.nodes.count as string)
delete objects
d = dummy name:"Node_Holder"
for k=1 to 10 do box()
custAttributes.add d nodeTabAttr baseobject:on
for obj in objects where obj != d do append d.nodes obj
select d
max modify mode
