De-Instance materials
By David_Lee · 2013-06-30
I need to rename all the SubMaterials in scene adding a "Sub_" prefix.
To doing this, I wrote a simple script:
for o in sceneMaterials do
        if (classof o == Multimaterial) then
		for i in o.materialIdList do
			try
				subo = o[i]
				subo.name = "Sub_"+subo.name
			catch()
But the problem is that sometimes, a submaterial is an instance of another material in scene and if I rename the submaterial, the master material is renamed too.
So, how can I check if the submaterial is an instance and, if it is, make it unique and then rename it?
Someone could help me, please?
Thanks,
David
To find all instances of a material check this
To make material unique see what is written in maxscript help file:
assignNewName <material>
Modifies the name of the specified material to make it unique. The name is of the form "Material #1" where the number is incremented as required to make ensure it’s unique.
Reply to miauu
David_Lee
Tried using assignNewName, but it doesn't make the submaterial unique. It rename both submaterial and master material as "Material #n".
Reply to David_Lee
Same behaviour here. Maybe we don't know how to use it. I started a thread in cgtalk. Hope someoane to gives us the answer. :)
Reply to miauu
David_Lee
It works!!
Thanks a lot miauu!!
I know how to use it, I have the answer! :)
			try
				subo = o[i]
				tmp = copy subo
				o[i] = tmp
				o[i].name = "Sub_"+subo.name
			catch()
Reply to David_Lee
I think I found a sloution:
The first slot in Material Editor is a multisub. All submaterials are instances of subMat[1]
-- the first slot is multisub mterial. All submat-s are instances of submat[1]
msm = meditmaterials[1]
-- get the second submat
-- create a copy
tmp = copy msm[2]
-- assign the copy back
msm[2] = tmp
