Custom UI register/unregister dialog bar
By Nico · 2014-12-06
Hi everybody, new to this forum, I'm coding a script to help myself with some stuffs I like to use and for that I'd like to make a floating toolbar, dockable to the Max UI just by clicking/unclicking one button.
I don't know why, but at first this worked (By clicking the button and uncheking it back)
But for some unknown reasons I now got an error without changing anything in the code :
" -- Runtime error: Requires a Rollout or RolloutFloater, got: undefined"
Here is the code :
macroScript Toolbox_Utility_Script
category:"Toolbox Utility"
toolTip:"Toolbox Utility"
local isOpen = false
on execute do
    if isOpen then
		cui.UnRegisterDialogBar Toolbox_Utility
		closerolloutfloater Toolbox_Utility
		isOpen = false
		Toolbox_Utility = newRolloutFloater "Toolbox" 160 1024
		cui.RegisterDialogBar Toolbox_Utility style:#(#cui_dock_all, #cui_floatable, #cui_handles)
		cui.DockDialogBar Toolbox_Utility #cui_dock_left
		isOpen = true
  on isChecked return isOpen
Thanks for lighting me on this! :)
MarkD
 It seems like you're trying to close a floater that doesn't exist and the script dies? Maybe try using a "Try/catch" instead of just trying to close the rollout floater that may or may not be there?
So instead of:
use:
try (closerolloutfloater Toolbox_Utility) catch ()
That way if it doesn't find a rollout floater it will carry on with the rest of the script.
You will also want to try to unregister the DialogBar when you try to close the rollout:
try (cui.UnregisterDialogBar Toolbox_Utility) catch()
Otherwise it just keep adding new rollouts. You might also need to use "DestroyDialog" instread of CloseRolloutFloater?
try (DestroyDialog Toolbox_Utility) catch()
